No power to the ECU??!!
hey guys i have a problem with my zc civic today, i parked in the garage for a week after autocrossing it and now it wont start!? it cranks but the ecu light isnt on?! i know when you starting up the ecu will flash and the fuel pump didnt prime
i checked all the fuse, switched ecu, checked dizzy, checked main relay.
! i checked all the fuse, switched ecu, checked dizzy, checked main relay.
i'd say put ur ear by the rear seat (above the fuel pump) and u should hear it if its working, otherwise since u autocrossed it did u drive it home?? i know here a guy seized his motor autoxing because no oil was getting to the sump. otherwise just check spark from wires and maybe change plugs, idk just some ideas tuff to help when i haven't seen it well good luck with it zc power
that happened to me too a while back after autocrossing...check all the fuses under the steering column. I forgot which one it is, but I never would have guessed it...I think it was an alternator fuse or something...the fuse powered the ecu and injectors too.
DeLorean00
Sep 7, 2019 09:54 AM
2 0 3
Jul 30, 2006 05:36 PM
