EG front and rear STB's from password JDM
well, i go to Wyotech and i'm in the chassis fabrication class right now and for my final project i want to make these STB's, but even stronger/stiffer. i also plan on putting in a SCCA spec roll cage and i might make a 23 or 24mm rear sway bar also if i have the time.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .Red.EM2 »</TD></TR><TR><TD CLASS="quote">I'm pretty sure he wants to put them in a coupe or something.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chunkybs »</TD></TR><TR><TD CLASS="quote">well, i go to Wyotech and i'm in the chassis fabrication class right now and for my final project i want to make these STB's, but even stronger/stiffer. i also plan on putting in a SCCA spec roll cage and i might make a 23 or 24mm rear sway bar also if i have the time.</TD></TR></TABLE>
Eh, so I was wrong, again.
for stronger and thicker bar, the password one looks hella thin and flimsy.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Made In OC »</TD></TR><TR><TD CLASS="quote">
for stronger and thicker bar, the password one looks hella thin and flimsy. </TD></TR></TABLE>
x2 gl
for stronger and thicker bar, the password one looks hella thin and flimsy. </TD></TR></TABLE>x2 gl
i'll post pics of my plans tomorrow, i just sketched out some things in class today. it will have more bracing between the bars. to stop any flex, not sure what size bar i will be using yet though
here is the sketch that i drew in class, as you can see still very rough at this point, once i get some measurements from the real bars and from my car i will be able to draw some better pics that are more to scale. but this will give you a rough idea
