driving without the o2 sensor on header
Old Oct 5, 2006 | 05:09 PM
Rex89's Avatar
Default driving without the o2 sensor on header
can this cause damage other from the check engine
Old Oct 5, 2006 | 07:23 PM
vtechdrex's Avatar
Default Re: driving without the o2 sensor on header (Rex89)
what up i got an 89 si and i haven't noticed a problem of course my o2 sensor is just unplugged (still in header) it won't really hurt your motor except that you are not properly exhausting which in the end means LESS POWER and god knows our beautiful rexes don't wanna be without speed, torque, and horsies so no it won't hurt your motor but you should fix it it's only around 80 for the new sensor good luck and let's keep the rexes running huh
Old Oct 5, 2006 | 10:15 PM
Tippyman's Avatar
Default Re: driving without the o2 sensor on header (vtechdrex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtechdrex &raquo;</TD></TR><TR><TD CLASS="quote">what up i got an 89 si and i haven't noticed a problem of course my o2 sensor is just unplugged (still in header) it won't really hurt your motor except that you are not properly exhausting which in the end means LESS POWER and god knows our beautiful rexes don't wanna be without speed, torque, and horsies so no it won't hurt your motor but you should fix it it's only around 80 for the new sensor good luck and let's keep the rexes running huh</TD></TR></TABLE>
wth?
Running with it physically out will leave a big *** hole in your header. it's essentially like running with a massive exhsut leak. I wouldn't think it'd hurt it, but it will sound like **** and you'll lose massive power from limp mode. Your car will run constantly rich and have a low rev-limit.
Old Oct 5, 2006 | 10:30 PM
mr.speaker's Avatar
wil run rich damige cat an eggszaust if u leev it 4 a long time
Old Oct 5, 2006 | 10:32 PM
Tippyman's Avatar
Default Re: driving without the o2 sensor on header (brijpurt13b)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brijpurt13b &raquo;</TD></TR><TR><TD CLASS="quote">wil run rich damige cat an eggszaust if u leev it 4 a long time</TD></TR></TABLE>
O god-damnit, not you again...
Old Oct 5, 2006 | 10:34 PM
mr.speaker's Avatar
Default Re: driving without the o2 sensor on header (Tippyman)
i try 2 log in an it wood not let me log in so i had 2 mak new acont agan 4 sum reeson my acont keep get deleeted dis lik 5-th time i hav acont
Old Oct 5, 2006 | 11:06 PM
Tippyman's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by brijpurt13b &raquo;</TD></TR><TR><TD CLASS="quote">i try 2 log in an it wood not let me log in so i had 2 mak new acont agan 4 sum reeson my acont keep get deleeted dis lik 5-th time i hav acont</TD></TR></TABLE>
Stop making accounts. If you are going to be on this website, type normal words and talk like a human being.
The reason they were deleted is because you are an idiot.
Old Oct 6, 2006 | 04:33 AM
Rex89's Avatar
i still have the old 02 sensor in my ostock header but its seems to be melted in and wont bugde which i can understand 17 years of heat could do that
Old Oct 6, 2006 | 07:14 AM
CRX_1.8T's Avatar
Have you tried to slip a pipe over the end of your wrench to see if it will break loose with some leverage?
Old Oct 6, 2006 | 02:05 PM
2slow4stock's Avatar
ditto. for the guy above. How did you try to take off the o2 sensor? When the exhaust manifold is on the motor or off of it. If worst comes to worst just go to the junk yard...
Old Oct 6, 2006 | 03:03 PM
Jonknee's Avatar
Default Re: (2slow4stock)
Your car will run rich and it doesnt have to go in limp mode, although it MAY, but it doesn't have to.
Old Oct 6, 2006 | 03:22 PM
Lil Red CRXsi's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Rex89 &raquo;</TD></TR><TR><TD CLASS="quote">i still have the old 02 sensor in my ostock header but its seems to be melted in and wont bugde which i can understand 17 years of heat could do that</TD></TR></TABLE>
You meen it's in your stock exhuast manifold.Take it to someone that knows how to use a tourch and let them try to get it out for you.
Old Oct 6, 2006 | 03:57 PM
boostedblkef's Avatar
[IMG][/IMG]
Old Oct 6, 2006 | 04:31 PM
Bob_760's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman &raquo;</TD></TR><TR><TD CLASS="quote">
O god-damnit, not you again...</TD></TR></TABLE>
hahahahahahahahahahahahaha
Old Oct 6, 2006 | 07:46 PM
Jonknee's Avatar
Default Re: driving without the o2 sensor on header (Bob_760)
Jesus christ,it's almost like you're trying to spell wrong on purpose
Old Oct 6, 2006 | 07:50 PM
Tippyman's Avatar
Use a big-*** breaker bar.
Old Oct 6, 2006 | 08:04 PM
salman's Avatar
Just rich nothing else,
If u want to save gas install it,
esle nothing will happpen,
Old Oct 8, 2006 | 09:31 PM
Rex89's Avatar
Default Re: (salman)
finally got the 02 sesor out hammer did the job took a while though
Old Oct 8, 2006 | 09:44 PM
cambopheonix56's Avatar
hahahahah sig.
Old Oct 8, 2006 | 11:02 PM
2poor2tune's Avatar
why would you take it out?
Old Oct 9, 2006 | 12:47 AM
darkspector2.0's Avatar
running rich constantly is not good for your rings
Old Oct 9, 2006 | 01:44 AM
trrbl1bmx's Avatar
someone should delete this thread. too many *** clowns( trials ) that dont even type full words for anything.
as mentioned before, you will run rich, lose power, and lower your rev limit
Old Oct 9, 2006 | 09:29 AM
95gsrturbo's Avatar
Default Re: (p00n)
another thing fo future use is "liquid wrench" or "PB Blaster" from any auto parts store.
Old Oct 9, 2006 | 10:37 AM
Jonknee's Avatar
Default Re: (95gsrturbo)
GET A PLASMA CUTTER
toolfan020
Apr 20, 2010 08:52 PM
project93accord
Feb 3, 2006 05:42 AM
Themouse
19
Feb 1, 2006 04:17 PM
f1uxx
May 8, 2003 09:45 PM
integraautox
Sep 23, 2002 01:18 AM
