supercharge d15??
Old Oct 5, 2006 | 04:04 PM
white ej2's Avatar
Default supercharge d15??
i was thinkin about supercharging my d15b7 but i wasnt sure if the stock motor could handle that.. does anyone know if its safe to do this or not??
Old Oct 5, 2006 | 04:07 PM
Libertariat's Avatar
Ek Forever y0!
Default Re: supercharge d15?? (Littlesriz)
All depends on miles/condition of the engine. I would rather piece together a turbo kit though.
Why are you going super? To be different?
Turbo lag is a myth if you get the right turbo. Just don't get a turbo that's made for Diesel trucks and you'll be fine.
Old Oct 5, 2006 | 04:09 PM
white ej2's Avatar
Default Re: supercharge d15?? (ek forever guy)
the motor has about 80k on it n i wanted the supercharger cuz it seems like there's less modifications needed n less fixing than with a turbo
Old Oct 5, 2006 | 04:11 PM
Ek Forever y0!
Not necessarily true. IMO I think superchargers are more difficult to work with. You ha e less options. A super-charger is belt driven so it's always on and making the same boost. Problem is, if you want more power you'll have to change the belts. Turbos can be made to work with boost controllers and have plenty of engine saving devices like a turbo timer and an intercooler.
Old Oct 5, 2006 | 04:15 PM
white ej2's Avatar
well if i went with the turbo wat mods would i have to make to the motor to make it suitable/strong enough to handle the boost
Old Oct 5, 2006 | 04:17 PM
Ek Forever y0!
either way it's boost. Just minor differences. 99% of civic drivers go turbo, why re-invent the wheel?
If you really want to you can upgrade the Throttle body. get titanium internals. Basically rebuild the head.
But for under 12 lbs stock internals will do just fine. Don't worry
btw, i recomend piecing one together or finding a cheap but good $800 kit on ebay. Just make sure parts are cast. When any parts go you can replace them with quality parts one at a time.
Tuning will be your friend too.
Old Oct 5, 2006 | 04:47 PM
white ej2's Avatar
kk.. thanks for the advice
Old Oct 5, 2006 | 05:46 PM
big-cat's Avatar
u wouldnt have to mod the motor unless u really want to be safe and most turbo guys have there stock motors turboed around 5-12psi but there is a guy named turbo_y8 on here with a stock d16z6 and hes runin 23psi @375whp and his motor survived a spike of 29psi makeing 425whp on a STOCK MOTOR!!!! craziest thing ive ever heard
Old Oct 5, 2006 | 06:51 PM
Syndacate's Avatar
Default Re: (big-cat)
Yeah, I heard about a guy running a B16 on 40psi and stock internals. Not sure if it was a hoax or not though. There was a video floating around on H-T awhile back with it dragging.
Old Oct 5, 2006 | 06:58 PM
bpkmrtoes's Avatar
d-series handle a **** load of abuse! I have a DD d15y7 running 8lbs of boost, runs strong; half a year already?
Old Oct 5, 2006 | 07:12 PM
D16 Power's Avatar
I'm running a d16y7/z6 stock bottom end on 18psi and no problems...
Old Oct 6, 2006 | 08:17 AM
teal_dx's Avatar
Just be sure to get it tuned, stay away from Fuel Management Units
chipped ECU (Uperdata or CROME etc..) is the proper way
Old Oct 6, 2006 | 08:22 AM
cambopheonix56's Avatar
Default Re: supercharge d15?? (teal_dx)
Dont listen to half the guys. You can run 100 lbs of boost on stock internals, as long as you don't go over the maximum whp the engine can handle. I am not sure what is it for thid particular motor, but around 220whp. Yes there are people making over 300whp on stock internals, but then it becomes unreliable.
Syndacate's Avatar
It's very funny how with a turbo an engine can break so easily without the proper tune but on the other hand it's so durable. What do I mean by durable? Awhile back (maybe 2 - 4 months) there was a video floating around H-T called like "D15B2 abuse" or something like that. They took this engine, slammed the rev limiter, drove through puddles as hard as they could to try and get it to hydrolock, ran it w/o coolant or oil. They beat the **** outta this engine to kill and it took a surprisingly long amount of time.
Funny when you think of that vs one bad tune in a turbo setup could easily = thrown rod...
Old Oct 6, 2006 | 11:44 AM
big-cat's Avatar
lol i remember that. not exhaust/header. they shot bannanas out of the exhaust port when they started the car. and used water for oil lol. best honda vid ever.
Old Oct 7, 2006 | 09:16 PM
Ek Forever y0!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by big-cat &raquo;</TD></TR><TR><TD CLASS="quote">lol i remember that. not exhaust/header. they shot bannanas out of the exhaust port when they started the car. and used water for oil lol. best honda vid ever.</TD></TR></TABLE>
wtf mate.
Old Oct 8, 2006 | 10:16 AM
ddd4114's Avatar
Default Re: supercharge d15?? (cambopheonix56)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambopheonix56 &raquo;</TD></TR><TR><TD CLASS="quote">
Dont listen to half the guys. You can run 100 lbs of boost on stock internals, as long as you don't go over the maximum whp the engine can handle. I am not sure what is it for thid particular motor, but around 220whp. Yes there are people making over 300whp on stock internals, but then it becomes unreliable. </TD></TR></TABLE>
agreed
75aces
29
Dec 19, 2011 02:38 PM
dk-fabrications
Oct 17, 2004 12:04 AM
Briman2021
Oct 28, 2003 08:34 AM
^MikeG
Sep 27, 2003 03:36 AM
MachAF
Nov 9, 2002 09:02 AM
