Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
FAQ: for D17 internals build up 305whp
Old Oct 5, 2006 | 04:01 PM
supermex's Avatar
Default FAQ: for D17 internals build up 305whp
Here is the only COMPLETE FAQ with real info on how to build your d17 the right way, make it sticky, I know it would help.
No short cuts where taked when building this engine, Sleeves whether are needed or not they are there doing their job.
All my parts where research and developed from scratch other than the obious (turbo,block, guard and,,, just it) I didn't purchase any bolt on parts.
The need of notching the D17 was first discovered and done by yours truly the same goes for the ARP studs, fuel system, intakes etc.
Pistons developed specialy for me by Racing Engineering out Florida and they have being already avilable since 2004
NOW THIS ENGINE IS ON A FULL STREET TUNED CAR. This engine is driven almosty every day for the last 2 years with no problems at all.
(exteremely relaiable)
Fully functional with A/C and all the amenities, the motor is done done no excuses here!
I'll be at NOPI 2006 in Atlanta and I'm driving there and back to Florida for anyone that cares to check it out in person.
Well, I read all the stories of engines go bad after turbocharging.
I figured since some of you already bought the turbo kit and had a bad experience with the engine cause of improper installation or to much boost is time to rebuild.
If you are going to all the trouble get it done, then do it right with the proper internals.
I had my engine done in preparation for a turbo and I would like to share my experience with the project.
Project starting date Jan 03
First it will help to get a Honda Factory service manual, it will be your bible when building your engine
You can order one from www.factoryautomanuals.com
Is better to get a motor to work with , keep your original as spare.
Q: Were can I find another motor?
A: By now you may be able to get one at the auto recyclers.
Try your local places or the website http://car-part.com/ there is a lot of places that will have one for sure.
I bought my block and head from a car that blew a head gasket after an accident and ran with it for awhile the insurance paid for a new one.
I got it for $600.00 back in 2003 now you may find them a lot cheaper.
Q: Can I use my own block?
If you didn't have a major malfunction that cracked the block or sleeves you may still use your own motor.
You may have a mechanic take it out of your car or if you have the tools and garage rent an engine hoist and do it your self.
Q: Once I have the block what do I do?
A: Since my stock engine was running fine and I purchase the block I was able to safe money by take in it apart in my garage.
I bought an engine stand for $80.00 an the Honda service manual for $100.00
It was very educational and a lot of fun striping that block bare.
I could do no harm since it was already messed up.
(note) save all the screws, bolts and extra parts you'll need them on the future.
Q:What parts do I need and were do I get them?
A: At the time there was no pistons or sleeves for this block so I hit the web and started calling manufacturers.
I found a place in Lake Worth Florida were they do research and design parts for well known manufacturers.
The place is call Race Engineering Tel: (561) 533- 5500 ask for Jonh if you call him, deffinately tell him I, Hector told you about them and he'll work you a discount also tell him about our 7thgencivic site.
Any way I took the bare block to him with a stock piston.
And they designed a full floating piston and had Wiseco build it.
(Full floating piston are pistons that use a losse connecting pin that attaches them to the rod as opposed to the pressure conecting rods from stock reducing friction,they are a bit noisy and rattle when the engine is cold)
At the time I went for a bigger size piston 76mm (stock 75.02mm)
Piston part # XT- 519P76 Wiseco 76mm 9:01 compression about $450.00
I check my compression at about 95 lbs after installing this pistons
(stock 135- 145 lbs)
Wiseco now makes 75mm pistons (stock size)
Tell them that you are turbocharging and they will recomend the right set of rings and gap clearence.
depending on how much HP and size of turbo you'll be using the type of rings will be suggested.
Heat will expand and contract this rings so gap and type of rings will make a difference if you are racing at the track of just if you just driving day to day
Definately talk to the ppl at Racing Eng. for your application
Sleeves part #DS-300-010 Darton flanged sleeve from a D16- 75mm
I had to bore this babes out to 76mm to fit my oversized pistons.
Skip this step if you are using 75mm pistons.
About $210 a set of 4
Rods where already available CR- BR3740B Crower Billet Honda 1.7 $600.00
The good thing about Racing Engineering is that they will give you all the specs and measurements that you need for the machine shop.
This sure helps if you are not a car guru.
Q: And theeeen?
Take the block and parts to a machine shop and give them the specs that you'll get from Racing Eng. along with the Honda service manual
The block will have to be bored to fit the sleeves about 78mm and the cranck shaft line honed.
Also make sure the shop resurface the top of your block so is nice and flat.
Sleeves pressed in and bore out to fit the size piston you choose 75mm or 76mm and the bottom of sleeves noched to make room for the crower bigger rods to clear ( bigger rods will touch the bottom of the sleeves as they turn up and down,
I found this out the hard way half way into the install.
Q: Now that I have all done how do I put it all together?
A; I deffinately recomend getting a good shop to do the job.
Make sure they are proficient in Hondas and take with you the service manual and ask them to see it carefully and use all the torque recomendations.
I would also purchase a gasket kit and new cranck shaft bearings $160.00
Check the manual book to learn how to order your bearings they come in colors yellow brown green etc.There are numbers on the block and the camsaft as well as on the rods.
The bearings can be any combination of colors and almost unique to your block.VERY IMPORTANT!
I went OEM you may choose after market.
KMS Block Guard if you want one, $40.00 http://www.7thgencivic.com/for...guard
The BG is an insurance agains cathastorphic failure on your internals.
It sort of keeps thing togerher.
It works great on racing cars one 1/4 of mile at the time, but on a daily driver can get the engine overheated on hot days
(there has being issues with Block Guard heating up the head because it obstructs the free flow of water to the head)
So I modifed the BG to flow more water by opening the holes on a side to side configuration as shown below
Also I intalled a huge superthin front pusher fan placed between the intercooler and the A/C core Autozone $50.00
Now you can apply a Nippon head gasket sold at the dealership $40.00.
Follow up with a set of ARP heat studsARP headstuds
ARP part # 2084301 Honda D-16 HSK for 1.6 SHOC vtec application. 10 studs
NOTE: ARP makes two types Z&Y (OURS is Z) about a $100.00
Q: What about the head?
I had the head P&P and valves installed a month later and end up having a shop make an Intake manifold with a big throttle body 75mm
But that will be another FAQ all together.
P&P Head KMS
If I was you I would only have my head cleaned and a 3 angle valve job just to get the thing going again without spending more money.
Can always take the head out later and deal with it like I did.
Before the mechanic installs the engine I ask for a full day with it to polished the block and the head cover
My engine installed looks like this
A year later here is the turbo June 05
Update July 4-05
I'm working on a better fuel system and with the help of Optos electronics installed by optos I should be doing about 250hp hopefully.
UPDATE JULY 2006 fuel system taking care off, the return line was installed, on the bottom left you'll see a canister that holds a liter of fuel ready available for when boosting at WOT won't dry out your line.
A Walbro 240 intank pump and a Mighty might inline pump is installed on front with a custom made fuel rail with RC 540 injectors and a Aeromotive fuel pressure regulator holding 40 lbs of pressure.
Now Feb 06 after installing an EMS AEM and all the necessary additions like high flow fuel rail, Koyo radiator for cooling I started to dyno it at low 300 whp.
This is the final result on the car.
modifing the vic and representing Since 2001
Old Oct 5, 2006 | 04:17 PM
Todd00's Avatar
I said I don't want a title!
Default Re: FAQ: for D17 internals build up 305whp (supermex)
Added to FAQ.
Old Oct 9, 2006 | 06:27 PM
BojeEM2's Avatar
Default Re: FAQ: for D17 internals build up 305whp (Todd00)
wooow......I love it,it looks bad as, what type of headlights are thoughs???? I really need to know thanks
Old Jan 27, 2007 | 07:12 AM
Yas's Avatar
Yas
Default Re: FAQ: for D17 internals build up 305whp (BojeEM2)
HI, just wanted to ask how much did it cost to get all that done to your car?
Old Jan 27, 2007 | 09:10 AM
toyomatt84's Avatar
Sanji
Default Re: FAQ: for D17 internals build up 305whp (Yas)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Yas &raquo;</TD></TR><TR><TD CLASS="quote">HI, just wanted to ask how much did it cost to get all that done to your car?</TD></TR></TABLE>
You're looking at $12k - $15k for what was done up to that point. He's pushing $20k in the engine now.
Old Feb 7, 2007 | 11:54 AM
flamega's Avatar
Default Re: FAQ: for D17 internals build up 305whp (toyomatt84)
wow! there is hope after all.
beautifully done.
Old Feb 8, 2007 | 12:47 AM
AR_motorsports's Avatar
W0W! personally I don't want that much in my car, but W0W -way to rep man
Old Feb 8, 2007 | 05:53 PM
berettagtz117's Avatar
That is badass!! Very nice work!
Old Feb 28, 2007 | 10:15 PM
pearl62's Avatar
What are the specs for the turbo? Is that a T3/T04e? What trim and A/Rs?
I am building a D17 also, and really like that dyno curve...
Old Jun 22, 2007 | 10:55 AM
mustgofast's Avatar
do you build these motor cause i would like to get one for my 04 d17a2 if you dont please contact 480 343 5953 cause im willing to put the monet down for one thanks
Old Jun 22, 2007 | 06:45 PM
menappi's Avatar
Default Re: FAQ: for D17 internals build up 305whp (mustgofast)
SICK! Sorry this is more of a newb question, but where'd you get those angel eye lights from? and what color?
Old Jul 16, 2007 | 07:12 AM
elsombradelsol's Avatar
Simple question here, how much of a gain, if any, did you notice from the NX intercooler kit? I've heard that it doesn't make a difference below 400HP and i'm at 300WHP in my del sol. My revs are high b/c i've got a JDM ITR so i figured the extra cooling on the charge air would also help cool my head a little more. Did you think it was worth it? ?
Old Nov 9, 2007 | 02:58 AM
DGAeveryday's Avatar
nice build man, hoping to see those kinds of numbers in the future!
Old Nov 18, 2007 | 05:13 PM
2002civicd17's Avatar
how did u get that intake manifold made and for how much? is it necessary to get a new one?
Old Nov 18, 2007 | 05:52 PM
toyomatt84's Avatar
Sanji
Default Re: FAQ: for D17 internals build up 305whp (2002civicd17)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2002civicd17 &raquo;</TD></TR><TR><TD CLASS="quote">how did u get that intake manifold made and for how much? is it necessary to get a new one?</TD></TR></TABLE>
The stock intake manifold is plastic. If you want to run over 10psi, you'll need to replace it.
Old Nov 19, 2007 | 06:59 PM
burke420's Avatar
hector knows his D17.. for a true car that has power.... this is his... and even better in person!
Old Nov 19, 2007 | 07:09 PM
Curiouz_G's Avatar
where has he been lately? i wonder what has happened to that car of his.
Old Apr 8, 2009 | 08:51 AM
SLO03EM2's Avatar
NICE WORK!!! Im working on a build now..lookin to push 15 LBS...but i need an intake mani. Who fabricated yours?
Old Apr 8, 2009 | 10:23 AM
Curiouz_G's Avatar
hes out of the D17 game. check civicforums.com to see if he has any info still there. i do know that it is custom.
Old Apr 8, 2009 | 11:52 AM
rEM2's Avatar
JDM fabtech is what some guys were using such as andyman who was at 400whp. Its roughly $1k for it but worth it. Search it I think Steve is selling his on the for sale thread.
Old Apr 8, 2009 | 03:57 PM
Curiouz_G's Avatar
That's only if he's willing to make it for you.
Old Dec 12, 2009 | 02:06 PM
kuki22's Avatar
We are pushing 22psi out of a GT28R turbo on the STOCK intake manifold. So far only issue has been....a head gasket
The D17 is making a solid 326whp on RedZone's dyno.
Old Sep 15, 2010 | 02:41 AM
JDHudd's Avatar
is that d17 an sohc or dohc cause mine is sohc
Old Sep 15, 2010 | 03:31 AM
GriFFIthS's Avatar
a stock DOHC D17 doesnt exist, they were all Single
Old Sep 15, 2010 | 10:04 AM
It Wasn't Me's Avatar
Not to mention the fact that the engine in the photos only has one cam gear on it.
Nick Durkin
May 4, 2013 01:54 PM
ScubaStevo80
Feb 9, 2006 10:26 AM
aznegg
Jan 13, 2006 01:03 PM
quik sol
Apr 10, 2005 12:55 AM
accordfreak
Feb 4, 2002 03:59 PM
