How are my numbers?
Old Oct 5, 2006 | 02:24 PM
nighttrain33's Avatar
Default How are my numbers?
I finally got my new oil pump installed, and have been driving around on my car since yesterday. My idle oil pressure is between 15-20 psi, and just driving around it is between 50-60 psi (depending on rpms) while driving. My vtec is kicking strongly again, i.e. not in-and-out like it was with the old pump.
I have seen some other numbers when I searched, but I wanted to get opinions on what my numbers are. Any feedback would be appreciated.
-Shane
Old Oct 5, 2006 | 05:41 PM
Default Re: How are my numbers? (nighttrain33)
Bump? I know H-T is full of help and opinions.
-Shane
Old Oct 5, 2006 | 05:48 PM
mc's Avatar
mc
sounds about the same as my turbo sohc
Old Oct 5, 2006 | 06:33 PM
Crx Jimmy's Avatar
my b16 when warm is 25-30psi at idle and about 80 psi cruising
Old Oct 5, 2006 | 06:37 PM
Luserkid's Avatar
Default Re: How are my numbers? (Crx Jimmy)
Your motor is perfect glad to see you finished the job
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">my b16 when warm is 25-30psi at idle and about 80 psi cruising </TD></TR></TABLE>
Those are pretty high numbers.
Old Oct 5, 2006 | 06:47 PM
Crx Jimmy's Avatar
Default Re: How are my numbers? (Luserkid)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">
Those are pretty high numbers. </TD></TR></TABLE>
how do you figure? they seem pretty healthy to me
Old Oct 5, 2006 | 07:01 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid &raquo;</TD></TR><TR><TD CLASS="quote">Your motor is perfect glad to see you finished the job </TD></TR></TABLE>
Thanks! It didn't take me too long to put it back together, just a bitch to keep the cams and crank timed when putting the belt back on.
-Shane
Old Oct 6, 2006 | 12:09 AM
Luserkid's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crx Jimmy &raquo;</TD></TR><TR><TD CLASS="quote">how do you figure? they seem pretty healthy to me</TD></TR></TABLE>
What oil pressure gauge are you using? Every car that i have worked on (honda) with an oil pressure gauge never sees over 60 crusing and is always 10-20 at idle. Only time i could see 80 would be revving high. What is your reading when your in high RPM?
Old Oct 6, 2006 | 08:24 AM
Being that I am using a manual oil press. gauge, is it normal that it takes a couple seconds for the gauge to read correctly? I would think so, but just want to make sure. I know that in my truck, pressure reads almost instantaneously from about 55 psi cruising to about 70 at WOT (on an electric oil press. guage of course).
-Shane
sasinorm01
Nov 21, 2006 07:26 PM
hybridpatient95
May 27, 2005 04:05 AM
s2kkid
May 1, 2005 06:19 AM
s2kkid
Apr 25, 2005 02:31 PM
wade
May 16, 2004 11:08 PM
