would closing the gap on spark plugs help with unburnt fuel?
Old Oct 5, 2006 | 10:05 AM
iphatcrxi's Avatar
Default would closing the gap on spark plugs help with unburnt fuel?
i had high HC from emissions and im trying to figure out ways to lower them, any input is appreciated
Old Oct 5, 2006 | 09:58 PM
lthao61's Avatar
Default Re: would closing the gap on spark plugs help with unburnt fuel? (iphatcrxi)
no.
Old Oct 5, 2006 | 10:15 PM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: would closing the gap on spark plugs help with unburnt fuel? (lthao61)
If your trying to pass emissions, that usually means your CAT isn't functioning like its supposed to. As a quick fix to pass, use an adjustable FPR to lean you out a little bit.
Old Oct 6, 2006 | 11:41 AM
thesmogman's Avatar
Unburnt fuel... no. I would run the manu's spec.
Run injector cleaner through it. You might have one that is not squirting like it should be.
A tune-up could help Cap and rotor.. If you haven't done it in awhile.
O2 sensor, water temp sensor, intake air temp sensor. These might help.
I would start with an O2 sensor it is a one of the main sensor the computer uses to try and figure out the Air/Fuel ratios.
If these fail then a cat maybe next.. What was your O2 reading from the test?
sam hain
Dec 21, 2013 10:34 PM
jdmsir4dr
Mar 24, 2013 11:50 AM
Nameless Warrior
Apr 24, 2007 01:05 PM
Perfectionist
Oct 8, 2006 02:00 PM
vtec69
Jun 5, 2004 11:24 AM
