Best High Rev mods
Old Oct 5, 2006 | 09:57 AM
M!lly's Avatar
Default Best High Rev mods
what are the best supporting mods to be able to rev high safely
reason i'm asking is because i might be getting a chippd ecu that will allow my car to rev alot higher than it can stand.
i won't be reving high all the time on purpose just want to be safe in case i miss a gear or so on.
i have a USDM GSR basically stock.
any help won't be greatly appreciated
Old Oct 5, 2006 | 10:09 AM
Hardt's Avatar
Default Re: Best High Rev mods (Mines)
The ability to make power in the high rev range I think would be the most important of all factors. Theres not much of a point to take it beyond where the power curve starts to taper off. Find out where your car makes power and rev accordingly.
Old Oct 5, 2006 | 10:12 AM
M!lly's Avatar
Default Re: Best High Rev mods (Hardt)
well i'm swapping ecu's with someone to benefit him
and his old ECU revs to 9500 i know for sure my car can't handle me missing a gear and getting anywhere near 9500
so i wanna prevent the early death of my motor by getting supporting mods that make it so the engine can handle being revved that high
Old Oct 5, 2006 | 10:18 AM
JCushing's Avatar
so you want to put in forged rods, new bearings, good valvesprings, and a good breather setup only so your motor can handle the RPM limit of the ECU your are using?
normally you build the ECU around the engine not build an engine around the ECU...
Old Oct 5, 2006 | 10:26 AM
2'z kuztoms's Avatar
From: Streets of Sacramento...But now living in So Cal, usa
Default Re: Best High Rev mods (JCushing)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JCushing &raquo;</TD></TR><TR><TD CLASS="quote">so you want to put in forged rods, new bearings, good valvesprings, and a good breather setup only so your motor can handle the RPM limit of the ECU your are using?
normally you build the ECU around the engine not build an engine around the ECU...</TD></TR></TABLE>
Old Oct 5, 2006 | 10:33 AM
M!lly's Avatar
only reason i'm getting the ECU is to help someone out
i didn't intentionally get the ECU to build the motor around
Old Oct 5, 2006 | 01:13 PM
Hardt's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mines &raquo;</TD></TR><TR><TD CLASS="quote">well i'm swapping ecu's with someone to benefit him
so i wanna prevent the early death of my motor by getting supporting mods that make it so the engine can handle being revved that high</TD></TR></TABLE>
1. Drive better
2. Get a MSD ignition set up and set your limiter at whatever you feel is right for your car.
Old Oct 5, 2006 | 01:21 PM
91SiZ6's Avatar
Or just get a chip with the stock program.
Old Oct 5, 2006 | 02:53 PM
zCivic's Avatar
Default Re: (91SiZ6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 91SiZ6 &raquo;</TD></TR><TR><TD CLASS="quote">Or just get a chip with the stock program.</TD></TR></TABLE>
Yup.
Old Oct 5, 2006 | 03:32 PM
kaoss_11's Avatar
B A N N E D
or build the head
Old Oct 5, 2006 | 03:57 PM
Hater's Avatar
...or keep your stock ecu.
Old Oct 5, 2006 | 04:22 PM
Uncle Willie's Avatar
Default Re: (Enerjohn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Enerjohn &raquo;</TD></TR><TR><TD CLASS="quote">...or keep your stock ecu.</TD></TR></TABLE>
X2. Ur gonna help someone else out by saving them a few bucks, but u want ur motor to rev up to his ecu, which will cost ATLEAST a grand. Screw helpin ur buddy.
Old Oct 5, 2006 | 06:53 PM
kaoss_11's Avatar
B A N N E D
Seriously. Why not do a build and retune the ecu.
Old Oct 5, 2006 | 09:21 PM
Tomcat's Avatar
It's commendable that you want to help your buddy, but you might be better off loaning him some money instead of losing the correct ECU for your car. Your engine as it sits would not survive a missed shift going to 9500 RPM. I have the rev-limiter set for 9200 on my fully built motor.
thegatekeeper14
11
Aug 20, 2006 03:44 PM
b16a27
Mar 17, 2005 12:06 PM
arielmalespin
32
Jan 26, 2005 05:09 PM
dominate9
Jun 17, 2003 03:14 PM
MrJasey
Jan 13, 2003 09:05 AM
