6pt or 12pt socket set??
Old Oct 5, 2006 | 07:09 AM
sicones's Avatar
Default 6pt or 12pt socket set??
I need to get a deep throat metric socket set, should I get a 6 point or 12 point set, what do you prefer??
Old Oct 5, 2006 | 07:32 AM
hondacivic995's Avatar
Default Re: 6pt or 12pt socket set?? (sicones)
6 point, they actually grip the nut very well. 12 pt just strip everything and suck. 6 point FTW
Old Oct 5, 2006 | 07:48 AM
snoochtodanooch's Avatar
12 points are good when you need them, ex flywheels and such
Old Oct 5, 2006 | 08:16 AM
JK_Motorsports's Avatar
Default Re: 6pt or 12pt socket set?? (snoochtodanooch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by snoochtodanooch &raquo;</TD></TR><TR><TD CLASS="quote">12 points are good when you need them, ex flywheels and such</TD></TR></TABLE>
use 6 pnt when you have 6pnts, and 12 when you have 12. Simple.
Old Oct 5, 2006 | 09:15 AM
Howitt's Avatar
Default Re: 6pt or 12pt socket set?? (JK_Motorsports)
purchase both you cant have enough of the correct tool for the job
Old Oct 5, 2006 | 01:20 PM
Finest's Avatar
Default Re: 6pt or 12pt socket set?? (Howitt)
Gator-grip, FTW!
Old Oct 5, 2006 | 01:38 PM
JunY's Avatar
Default Re: 6pt or 12pt socket set?? (Finest)
6pt
Old Oct 5, 2006 | 02:45 PM
MajorPayne's Avatar
Default Re: 6pt or 12pt socket set?? (JunY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JunY &raquo;</TD></TR><TR><TD CLASS="quote">6pt </TD></TR></TABLE>
yeah 6 points work better and dont round off, but there are times when you ARE going to need 12 point wrenches, if you can only get one set for now, i would get the 12 points, but if you can afford both, get both sets, youll need em all
Old Oct 5, 2006 | 04:53 PM
sicones's Avatar
I'm going to go with the 6pt set for now, the only 12pt bolt I came in contact with so far was the flywheel bolts. I have a set of sockets for that, there just not deap throat....thanks
Old Oct 5, 2006 | 05:22 PM
MajorPayne's Avatar
well personally id go with the 12 pt first...here is why, and it has nothing to do with whether they are 12 pt bolts or regular 6 sided: when you get a regular 6 sided bolt in a tight spot where you can only move the wrench about 20 degrees, youll be wishing you had the 12 pt
Old Oct 5, 2006 | 05:30 PM
shortyz21's Avatar
Default Re: (MajorPayne)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MajorPayne &raquo;</TD></TR><TR><TD CLASS="quote">well personally id go with the 12 pt first...here is why, and it has nothing to do with whether they are 12 pt bolts or regular 6 sided: when you get a regular 6 sided bolt in a tight spot where you can only move the wrench about 20 degrees, youll be wishing you had the 12 pt</TD></TR></TABLE>
did u read the topic. SOCKETS
Old Oct 5, 2006 | 05:34 PM
MajorPayne's Avatar
Default Re: (shortyz21)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shortyz21 &raquo;</TD></TR><TR><TD CLASS="quote">
did u read the topic. SOCKETS</TD></TR></TABLE>
yes i did, but evidently too fast, thanks for pointing that out
Old Oct 5, 2006 | 05:35 PM
sicones's Avatar
lol
Old Oct 5, 2006 | 05:47 PM
MajorPayne's Avatar
Default Re: (sicones)
ok so speed reading owns me
but in my defense the way i was looking at it is its always best to have the tools to do more jobs, then get the specialty tools later
if that makes any sense
Old Oct 5, 2006 | 05:54 PM
sicones's Avatar
I know what you mean, I'm getting a set of 12pt wrenches too
Old Oct 5, 2006 | 06:35 PM
Dangger's Avatar
i bought a 12pt deep set and regretted it... should have bought a 6pt deep and have a regular 12pt.. the flywheel is 12pt but you don't need a deep... it's more cumbersome if you use a deep socket on something with shallow bolts.
Old Oct 5, 2006 | 08:03 PM
tfnaaf's Avatar
sometimes the 12 pt comes in hand when in a tight space
Old Oct 5, 2006 | 08:24 PM
MajorPayne's Avatar
Default Re: (tfnaaf)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tfnaaf &raquo;</TD></TR><TR><TD CLASS="quote">sometimes the 12 pt comes in hand when in a tight space</TD></TR></TABLE>
thats all i was saying, either way its not a big deal, i know i hate it when i dont have the right tool for the job though
Old Oct 7, 2006 | 10:03 PM
Kelly.'s Avatar
I've quit using this account
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Howitt &raquo;</TD></TR><TR><TD CLASS="quote">purchase both you cant have enough of the correct tool for the job</TD></TR></TABLE>
couldnt agree more
Old Oct 7, 2006 | 11:01 PM
MidShipCivic's Avatar
6 pt = for high torque.
12pt = for limited space for turning.
Old Oct 8, 2006 | 06:58 AM
RC000E's Avatar
Default Re: (MidShipCivic)
Basically, what you want to do is buy tools constantly regardless if you'll ever use them more than once or not. Assemble a list of usage priority and cost, then buy, buy, buy. The only time you should stop is if your wife threatens to leave you...until that time just simply continue to spend.
If she does find out then your going to have to start "needing" things from the store on occasion, a little more gas in the car, a present for the mom....basically a bunch of fake excuses to bank extra dollars which can be spent on tools in secret.
Sometimes I actually have to get out of my car and run up the driveway in a sprint to keep from being seen on my way to the garage with bags in hand, but I sure do have alot of tools. Mail order is also great...some companies ship in very low key, incognito named boxes which contain tools. Kind of similar to buying *****'s online and such... Judge the book by the cover is the way of the world....nothing to see here.....nothing to see here...move along people.
Old Oct 8, 2006 | 08:02 AM
xerox445's Avatar
Default Re: (RC000E)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC000E &raquo;</TD></TR><TR><TD CLASS="quote">Basically, what you want to do is buy tools constantly regardless if you'll ever use them more than once or not. Assemble a list of usage priority and cost, then buy, buy, buy. The only time you should stop is if your wife threatens to leave you...until that time just simply continue to spend.
Sometimes I actually have to get out of my car and run up the driveway in a sprint to keep from being seen on my way to the garage with bags in hand, but I sure do have alot of tools. Mail order is also great...some companies ship in very low key, incognito named boxes which contain tools. Kind of similar to buying *****'s online and such... Judge the book by the cover is the way of the world....nothing to see here.....nothing to see here...move along people.</TD></TR></TABLE>
Old Oct 8, 2006 | 04:23 PM
sicones's Avatar
Default Re: (xerox445)
LMAO!
Old Oct 9, 2006 | 04:34 AM
90DALS's Avatar
6point for the win.
insaneshoota
Audio / Security / Video
13
Apr 25, 2007 12:06 PM
jthm
Jan 16, 2007 06:40 AM
tnord
Dec 12, 2005 07:33 PM
RickJamesBitch
Jul 4, 2005 10:45 AM
ZygSpeed
Mar 20, 2004 09:06 AM
