ITR intake manifold help!!
I have a 95 GSR. I bought a spare B16 head that im building. Im putting an ITR intake maniold on my B16 head. What parts are needed for the throttle body? Do I need to get a new throttle cable and stuff? If anyone can give me a parts list and appox. How much everything is it’ll be greatly appreciated.
TIA
TIA
im getting b16 pistons and mugen head gasket. the head is going to portflow for a bath.
CR should be around 11.5:1
im getting the itr one because its a little cheaper and has pretty much the same results as the skunk2
CR should be around 11.5:1im getting the itr one because its a little cheaper and has pretty much the same results as the skunk2
...hmm that's too bad your GSR head gets no love.
Say, are you plannin on getting rid of your GSR head? and are you in the S.California area at all ?
[Modified by Katman, 4:48 PM 5/2/2002]
I would recommend the Type-R throttle cable. It's around $20-30 from the dealer.
And get the throttle cable bracket.
[Modified by b19coupe, 3:37 AM 5/3/2002]
cool. can i use my gsr TB on the ITR manifold? it should work correct?
if you check my skunk2 manifold upgrade page (sorry, unfinished), it's bascially the same procedure and parts used.
http://tiiite.b16a.com/tech/sk2manifold/
luvs2h8
Jun 7, 2012 11:15 AM
Rob!
May 1, 2006 06:12 AM
