OBD2A CAR WITH A OBD2B MOTOR (did a search)
Old Oct 4, 2006 | 08:11 PM
cutt's Avatar
Default OBD2A CAR WITH A OBD2B MOTOR (did a search)
DID A search couldn't find my answer. my buddy just replace his 96 d16y8 motor in his 96 civic ex . he got a 99 d16y8 to replace it. everything seems to run fine but it bogs at 2500 rpm and then its fine . just wondering if this is due to ecu being a obd2a. if so how can I correct it with out having to change the harness or ecu. thanks in advance
Old Oct 4, 2006 | 08:27 PM
cutt's Avatar
Default Re: OBD2A CAR WITH A OBD2B MOTOR (cutt)
bump
Old Oct 4, 2006 | 08:37 PM
fmrprojects's Avatar
its the same motor. do a tune up. your ignitor might be going bad. tps might have a flat spot in it
Old Oct 4, 2006 | 10:05 PM
cutt's Avatar
Default Re: OBD2A CAR WITH A OBD2B MOTOR (fmrprojects)
any other ideas thanks
Old Oct 4, 2006 | 11:33 PM
sal's Avatar
sal
The same thing just happened with my buddies 97 ek we just put a 99 b16 into. Still havent figured it out. I'm guessing you used the obd2a motor harness? Did all of the sensors plug in?
Old Oct 5, 2006 | 12:11 AM
Timmay's Avatar
Default Re: OBD2A CAR WITH A OBD2B MOTOR (sal)
well what engine harness did you use? timing set? any CEL's?
Old Oct 5, 2006 | 04:08 PM
cutt's Avatar
Default Re: OBD2A CAR WITH A OBD2B MOTOR (Timmay)
obd2a engine harness , no cels and the installer set the timing
strider380
15
Jun 3, 2024 09:08 AM
Ladolcettad
Dec 13, 2011 07:32 PM
hondaluver19
May 10, 2011 06:08 AM
boostincoupe
Sep 10, 2006 08:34 AM
Eaglekper0046
Sep 27, 2005 09:41 AM
