COMPRESSION #s for d16z6 - WHAT ARE STOCK SPECS
Old Oct 4, 2006 | 04:08 PM
nichols_si's Avatar
Default COMPRESSION #s for d16z6 - WHAT ARE STOCK SPECS
whats the stock compression #'s for d16z6 from honda? like 180 or 110 thanks
Old Oct 4, 2006 | 04:12 PM
Soccerking3000's Avatar
Default Re: COMPRESSION #s for d16z6 - WHAT ARE STOCK SPECS (nichols_si)
i dont think it really matters as long as they are consistent between them all and there isnt more than a 5% differenc.
Old Oct 4, 2006 | 04:19 PM
Luserkid's Avatar
Default Re: COMPRESSION #s for d16z6 - WHAT ARE STOCK SPECS (Soccerking3000)
what numbers did you get and well tell you if its good or not.
Old Oct 5, 2006 | 12:37 AM
nichols_si's Avatar
LANDS AR GONE I THINK MOTOR WONT EVEN START
Old Oct 5, 2006 | 12:49 AM
Timmay's Avatar
Default Re: (nichols_si)
even with that low it should start and drive.. but yes that is low
Old Oct 5, 2006 | 05:44 AM
ddd4114's Avatar
Default Re: (Timmay)
I think 75 might be too low to start the car, or at least keep it running. Can you perform a leakdown test? That would help you pinpoint where the leak is.
Old Oct 5, 2006 | 05:50 AM
EG2Driver's Avatar
Default Re: (ddd4114)
did you do it with a warm engine with wide open throttle?
Old Oct 5, 2006 | 06:46 AM
nichols_si's Avatar
yea I might get on the leak down test.. well no.. an car wont start sorry man otherwise i would do it w/ warm. an yes WOT..
it was F/I before, an was on the way to get tuned, didnt really RIP it . gave some gas so i think it went.. but head looks all good springs/valves all tight nothing wrong it seems.. so 60 bucks for rings. gona do it an try that
lalocivic
Jan 4, 2010 07:27 PM
Skadaloz
Apr 8, 2008 10:02 AM
IVAN93EG
15
Jul 23, 2006 02:46 PM
TurboCRXD16
Sep 11, 2004 10:18 PM
T-RO
Apr 25, 2003 10:22 AM
