axle question
yeah basically it just stops right before that point where u hear it click in but it leaks massive oil. ive tried taking it out and puttin it back in but it stops at the same spot. thanks for your help.
when this happens to me, what i like to do is install it into the hub (with the spindle still being free). since now i don't have to hold it, i can focus on hitting the axle. and yes, you want to hit it where the nut will go through.
Take it out, re-postition it into the tranny and push it in. Go out to the other side of the axle and grab the hub with both hands. Push and pull the axle as hard as you can as if you were doing oush-ups, then it will go in. Don't worry nothing will happen, it will go in eventually. I had to do the same to mine just last week.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 »</TD></TR><TR><TD CLASS="quote">Take it out, re-postition it into the tranny and push it in. Go out to the other side of the axle and grab the hub with both hands. Push and pull the axle as hard as you can as if you were doing oush-ups, then it will go in. Don't worry nothing will happen, it will go in eventually. I had to do the same to mine just last week.</TD></TR></TABLE>
but doesn't that mean he has to release the lower ball joint to have play on the other axle? sounds like alot of work to me.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midnitesol »</TD></TR><TR><TD CLASS="quote">ok will try and if the spring clip is bent do ihave to replace it or can i bend it back? if not where can ifind it?</TD></TR></TABLE>
leave the ring alone. hammering it in will be your best bet and won't take long to get in.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by philosofy1 »</TD></TR><TR><TD CLASS="quote">
leave the ring alone. hammering it in will be your best bet and won't take long to get in.</TD></TR></TABLE>
yep...
yep...
but doesn't that mean he has to release the lower ball joint to have play on the other axle? sounds like alot of work to me.</TD></TR></TABLE>
Not necessarily, I did it with my car on jack stands.
well my lower ball joint was already undone and ive tried hammering i think i need a new axle nut but still no luck getting it in! im about to try these couple things will repost in a bit. Thanks for all your help!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midnitesol »</TD></TR><TR><TD CLASS="quote">well my lower ball joint was already undone and ive tried hammering i think i need a new axle nut but still no luck getting it in! im about to try these couple things will repost in a bit. Thanks for all your help!</TD></TR></TABLE>
Just pull and push in as hard as you can. BTW, where in So Cal are you?
just eat a can of spinach and you'll get it in popeye!
LOL. alright ive tried hammering and pushing and pulling and it kinda feels like its hitting the other side. is this possible or am i just not pushing hard enough?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by midnitesol »</TD></TR><TR><TD CLASS="quote">LOL. alright ive tried hammering and pushing and pulling and it kinda feels like its hitting the other side. is this possible or am i just not pushing hard enough?</TD></TR></TABLE>
is the inner joint housing sitting up against the tranny? there should be no gaps.
this is really not that difficult and shouldn't take this long to do. to make things alittle easier, add some bearing grease on the inner shaft and ring. then slide it in, or you may have to hit again with a hammer.
thanks alot for all of your help much appreciated!
