Civic DX. Did it have sway bars?
I did some searching but to no avail. Does the Civic DX have stock front or rear swaybars?
I know the Std has none, and the Si has both. But does the DX have any?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ontario-vtec »</TD></TR><TR><TD CLASS="quote">DX has a front swaybar, but no rear. I just installed an Si rear bar on my DX today
Hmmm...
Would this be worth installing on my Std.?
</TD></TR></TABLE>Hmmm...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tippyman »</TD></TR><TR><TD CLASS="quote">
Hmmm...
Would this be worth installing on my Std.?</TD></TR></TABLE>
Is it a direct bolt-on?
Hmmm...
exaclty correct.....i would think the biggest benifit would come from installing a good pair of aftermarket bars like ST like i have on my CRX...BIG difference.
</TD></TR></TABLE>exaclty correct.....i would think the biggest benifit would come from installing a good pair of aftermarket bars like ST like i have on my CRX...BIG difference.
Is it a direct bolt-on?</TD></TR></TABLE>
yes and no, you have to take the stock si mounts and weld them to plate that bolts onto where the rear tow hooks are.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Suck my DX »</TD></TR><TR><TD CLASS="quote">weird...my first dx had a front sway bar and my second did not</TD></TR></TABLE>
What years were they?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXhf_89 »</TD></TR><TR><TD CLASS="quote">
yes and no, you have to take the stock si mounts and weld them to plate that bolts onto where the rear tow hooks are.</TD></TR></TABLE>
I am talking about the DX front swaybar.
1) Is it even worth grabbing?
2) Is it a direct bolt-on?
oh my bad.
1) yes and the dx/si front sway is 18mm
2) yes https://honda-tech.com/zerothread?id=1436632
i hope that helps
i hope that helps
the front DX 3dr Hatch/CRX swaybar is the SAME as the Si 3dr Hatch/CRX bar, 18mm.
sedans had 19mm front swaybars.
no car other than the Si's, civic and CRX, had a REAR swaybar, and the chassis mountings for it.
civic STD hatch did not come with any front swaybar.
crx HF came with a smaller, hollow front swaybar.
installing a rear swaybar, of any thickness, will make a difference for the better.
here's a thread on what someone else alluded to mounting a Si or DA rear swaybar into a non Si chassis.
https://honda-tech.com/zerothread?id=1146145
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by marquisdee1018 »</TD></TR><TR><TD CLASS="quote">Would the front bar from a DX/Si be a direct swap for a HF?</TD></TR></TABLE>
yes. just need the bushings that are sized with it.
even a DA front swaybar will work. its 23mm hollow.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">from NO front sway to 18mm front sway? yes.</TD></TR></TABLE>
Hmm... cool. I may go thru the trouble of snagging it then.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Tyson »</TD></TR><TR><TD CLASS="quote">i noticed a difference going from 18mm to 19mm in the front.</TD></TR></TABLE>
Damn, really?!!
Damn, really?!!
railsk8a
Feb 3, 2011 04:30 PM
^Sammy]!.
22
Aug 10, 2004 04:00 PM
justinau
19
Apr 5, 2004 06:38 PM
