ARP HEAD STUDS:When installing to you tighten them all the way into the block??
Old Oct 3, 2006 | 03:01 PM
Xemu's Avatar
Default ARP HEAD STUDS:When installing do you tighten them all the way into the block??
Seems like they go too far into the block?? Also I accidently got coolant in the stud holes should I make sure their dry before installing the studs?? Don't want to harm the block when everything gets put under pressure?? Thanks for the help.........again.
Old Oct 3, 2006 | 03:31 PM
Autoworks's Avatar
Default Re: ARP HEAD STUDS:When installing do you tighten them all the way into the block?? (Xemu)
Which motor??
You should only hand tighten them into the block.
Old Oct 3, 2006 | 04:04 PM
gator88's Avatar
Default Re: ARP HEAD STUDS:When installing do you tighten them all the way into the block?? (Autoworks)
make sure the holes are dry before putting studs in. they will be under too much pressure, way too much and u could crack some ****.
Old Oct 3, 2006 | 04:15 PM
ludesrv's Avatar
Default Re: ARP HEAD STUDS:When installing do you tighten them all the way into the block?? (gator88)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gator88 &raquo;</TD></TR><TR><TD CLASS="quote">make sure the holes are dry before putting studs in. they will be under too much pressure, way too much and u could crack some ****. </TD></TR></TABLE>
Clean the holes up good. Water will compress, but it doesn't do so very well, same thing goes for oil, the pressure will overpower cheap aluminum shear stress and you will crack the block.
Now, the holes are clean good, you should look at the ARP studs paper that comesin the box for installation help! That's what that paper is, ohhh how nice . They should be torqued down to ARP spec, and then the head should be done the same way.
Old Oct 3, 2006 | 04:39 PM
Xemu's Avatar
Default Re: ARP HEAD STUDS:When installing do you tighten them all the way into the block?? (ludesrv)
This site rocks you guys are the best!! Couldn't be doing any of this stuff without all of you!! Thanks again!!
Old Oct 3, 2006 | 06:36 PM
highrev1987's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludesrv &raquo;</TD></TR><TR><TD CLASS="quote">
Not Realy.. have you every heard of hydrolic brakes?
Old Oct 4, 2006 | 05:42 AM
gator88's Avatar
Default Re: ARP HEAD STUDS:When installing do you tighten them all the way into the block?? (highrev1987)
i have, and it itsnt the same in my opinion. with hydraulic brakes, it is under pressure, but there is give, the pads give/move and also that is like mixing apples and oranges. brakes and head studs are different. just remember, opinions are like ********, everybody has one and thinks the other persons is shitty so...
Old Oct 4, 2006 | 06:22 AM
Not an opinion buddy liquids dont compress that much almost at all, if you apply an immense amount of pressure it will only comress a little bit. basic physics
Old Oct 4, 2006 | 06:34 AM
Tippyman's Avatar
I have heard some people torque the head studs down to 10 ft. lbs. because they sometimes don't seat right if only hand tightened. Sometimes something can get caught in a thread that will make it seem like it is tight.
Old Oct 4, 2006 | 06:14 PM
gator88's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by highrev1987 &raquo;</TD></TR><TR><TD CLASS="quote">Not an opinion buddy liquids dont compress that much almost at all, if you apply an immense amount of pressure it will only comress a little bit. basic physics</TD></TR></TABLE> i eat my words and learn something. physics and me dont get along. or can i blame it on my level three concussion i am recovering from, that works for everything else, im not thinking right
also, i was considering how i know of guys hydrolocking dirtbike motors when laid over in streams and they kick them till sa head cracks, yes i have seen it, but i understand we are not talking dirtbikes so ill just shut my mouth and listen and learn
Modified by gator88 at 10:34 PM 10/4/2006
Old Aug 14, 2007 | 07:59 PM
RNPoo7's Avatar
So we aren't suppose to tq them down to 12 lbs? Just hand tighen them?
Asking for a D16Y8 motor.
Thanks
Old Aug 14, 2007 | 08:15 PM
Tippyman's Avatar
Default Re: ARP HEAD STUDS:When installing do you tighten them all the way into the block?? (RNPoo7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RNPoo7 &raquo;</TD></TR><TR><TD CLASS="quote">So we aren't suppose to tq them down to 12 lbs? Just hand tighen them?
Thanks </TD></TR></TABLE>
When I installed mine, I use the little allen wrench key at the top ad hand tightened it down with the appropriate allen wrench. Make sure the threads are clean with a q-tip or pipe cleaner, and you'll be straight.
[ iLL ] iNt3GrA
Nov 16, 2009 02:34 PM
wernhersey
Mar 25, 2008 11:49 AM
skiracer8148
17
Apr 1, 2007 09:17 PM
B18EG6
Jan 22, 2005 10:15 AM
80884
Dec 8, 2004 04:09 PM
