Timing question
Old Oct 3, 2006 | 10:15 AM
Nicaraguense13's Avatar
Default Timing question
i juss did timing to my car its PERFECT the cams are at TDC and the block i tighten the tensioner and everything but i have the left side by the exhaust and right side by the alternator is tight and between the cams on the top loose a bit (alittle play ). Then i turn the crank pulley the top gets tight the part by the alternator gets tight but the front of the belt by the exhaust is loose is this right cuz i tighten the **** out of that tnesioner. yea juss need to kno if its normal or not.
Old Oct 3, 2006 | 11:06 AM
Default Re: Timing question (Nicaraguense13)
can anyone help me??????????
turboedsupe
Sep 19, 2008 04:32 PM
LS AzZkIkr
Mar 6, 2008 06:38 AM
Nicaraguense13
Oct 3, 2006 09:35 AM
91 ZC hatchback
Feb 27, 2006 10:52 AM
B18EG6
Jan 11, 2003 07:57 PM
