arp head studs - need torque specifications
Old May 2, 2002 | 01:07 AM
Brian_92GSR's Avatar
New User
Default arp head studs - need torque specifications
Does anyone know the torque specifications for the arp head studs for a b17a (I'm using the head studs for a b18c1)?
Old May 2, 2002 | 01:16 AM
poison's Avatar
Default Re: arp head studs - need torque specifications (Brian_92GSR)
hey i don't know if this will help. but go by your part number...
--Head Studs--
HSA11
rocker studs 5/16" 190,000 PSI 60 ft lbs
30 ft lbs 40 ft lbs
20 ft lbs
HSA11-B
30 ft lbs 40 ft lbs
20 ft lbs
HSA9
30 ft lbs 40 ft lbs
20 ft lbs
HSAH3 190,000 PSI 80 ft lbs 63 ft lbs
HSB42
30 ft lbs 40 ft lbs
20 ft lbs
HSBM70 190,000 PSI 135 ft lbs 95 ft lbs
HSC4201 190,000 PSI 85 ft lbs 70 ft lbs
HSC4301 190,000 PSI 85 ft lbs 70 ft lbs
HSC4601 190,000 PSI 85 ft lbs 70 ft lbs
HCS48 190,000 PSI 85 ft lbs 70 ft lbs
HSCB4601 190,000 PSI 85 ft lbs 70 ft lbs
HSCSW53 190,000 PSI 135 ft lbs 95 ft lbs
HSF38 190,000 PSI 130 ft lbs 90 ft lbs
HSFX48 190,000 PSI 85 ft lbs 70 ft lbs
HSGT6w 190,000 PSI 95 ft lbs 75 ft lbs
HSL68 x 190,000 PSI 85 ft lbs 70 ft lbs
HSMGC2 190,000 PSI 80 ft lbs 63 ft lbs
HSP4201 190,000 PSI 135 ft lbs 95 ft lbs
HSRV45 190,000 PSI 85 ft lbs 70 ft lbs
HST425-10 190,000 PSI 65 ft lbs 45 ft lbs
HST425-11 190,000 PSI 65 ft lbs 45 ft lbs
avotegra
Dec 27, 2015 01:26 PM
one pnt 6 hatch
Apr 25, 2005 08:48 PM
itralex
Oct 17, 2004 08:29 AM
D16A6Turbo
Dec 2, 2002 11:24 AM
saso
Jun 3, 2002 02:57 PM
