d16y7 with d16y8 head
oh well its just my motor to go in it now to get me from a to b while i build my fully built d with a nice t3/t4 set up.....so it will have less power then a y8? i thought the blocks were virtually the same and that the difference was all in the heads.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-Ek »</TD></TR><TR><TD CLASS="quote">uhh.. actully its lower compression bro.. good for boost</TD></TR></TABLE>
y7 block + y8 head is higher compression than a stock y8 motor (only by a couple tenths though). and the blocks themselves are almost identical, so it shouldn't make a difference which one you use.
you'll probably see about the same power as a stock y8, the compression bump is minimal and i doubt you'd notice any difference.
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UberMunkey »</TD></TR><TR><TD CLASS="quote">
you'll probably see about the same power as a stock y8, the compression bump is minimal and i doubt you'd notice any difference.</TD></TR></TABLE>
the difference is the VTEC crossover... you hear it more with a y8 block....
the difference is the VTEC crossover... you hear it more with a y8 block....</TD></TR></TABLE>
You actually can tell the different between a minimee to a full d16y8...
So my standard D16y7 engine with a Y8 head should show some power gains?
Also plan on a 1.4litre(1400cc) header(exhuast manifold) i'm told more free flowing as catalytic converter is smaller and located further back the system.
Right??
Right??
I thought D16Y7s were non-VTEC. Maybe I'm wrong....
*saracasm*
D16Y7 - non-VTEC
D16Y8 - VTEC
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coreyhayman »</TD></TR><TR><TD CLASS="quote">i blew my y8 bottom end, putting a y7 bottom on it now with my y8 head, how power will this set up make? less then the stock y8 or the same? </TD></TR></TABLE>
Search under "Mini-Me"
*saracasm*
D16Y7 - non-VTEC
D16Y8 - VTEC
JonGP4
29
Nov 21, 2003 10:35 PM
