idle issues in GSR swapped 99 EX
Old Oct 2, 2006 | 04:49 PM
Superdragr45's Avatar
Default idle issues in GSR swapped 99 EX
i put my GSR motor into my 99 coupe. its throwing a code 14 for the IACV. i cleaned it out several times and it still doesnt work. soo, i replaced it and i still get the same problem. anyone have any other ideas on this problem????
Old Oct 2, 2006 | 08:09 PM
xNOBOOSTx's Avatar
I was throwing an IACV code and it ended up being a vacuum leak on the Intake manifold. Check all you hoses and vacuum ports.
Old Oct 2, 2006 | 08:11 PM
Patron's Avatar
Default Re: (xNOBOOSTx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xNOBOOSTx &raquo;</TD></TR><TR><TD CLASS="quote">I was throwing an IACV code and it ended up being a vacuum leak on the Intake manifold. Check all you hoses and vacuum ports.</TD></TR></TABLE>
Good call, also check the adjustment screw.
Old Oct 3, 2006 | 03:15 PM
Default Re: (ptran13)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ptran13 &raquo;</TD></TR><TR><TD CLASS="quote">Good call, also check the adjustment screw.</TD></TR></TABLE>
r u talking about the adjustment screw in the TB????
also, i am using an LS TB......would that make a difference???
Old Oct 3, 2006 | 03:45 PM
xNOBOOSTx's Avatar
the actual throttle body itself shouldnt make a difference. but the way the adjustment screw is set, will affect the idle.
Old Oct 3, 2006 | 04:50 PM
k, ill have to check it out then.....................had same problem on my LS motor but at least it idled when it was cold. the GSR motor wont idle at all until its warm
MumBleZ_94gsR
May 8, 2009 07:19 AM
chickenwing
Sep 24, 2008 09:48 PM
P12 EG6
Oct 16, 2007 11:51 PM
Mr.Death
Sep 17, 2007 10:37 PM
SONIC BOOM
Jul 10, 2006 10:54 AM
