Idle surge [[need advice ASAP]]
Re: Idle surge [[need advice ASAP]] (wspcivic)
clean your IACV
make sure you have no vacuum leaks
bleed the coolant system.
thats where i would start
Re: (nutball72)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nutball72 »</TD></TR><TR><TD CLASS="quote">if your car is anything like mine, just give up cuz nothing works...</TD></TR></TABLE>
That was helpful....
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wspcivic »</TD></TR><TR><TD CLASS="quote">No bubbles, No vaccum leaks, and im not low on coolant.
clean out the IACV with brake cleaner, or is there anything else that could cause this?
Im not throwing any CEL's</TD></TR></TABLE>
Have you bled the coolant though? If there's an air bubble anywhere, it could cause this.
318 Curves, 11 miles
Sorry, didn't see your second post. Last time I had IACV problems, I cleaned it out with brake cleaner, but it didn't fix it. I threw a known good one in there, and the problem went away. Cleaning IACV works sometimes, but sometimes you just have to replace it.
Re: (xNOBOOSTx)
could be the pcv valve check that. let the car warm up to normal operating temp and find the vacuum hose for the pcv valve and pinch it close if the surge stops then you have found your problem
