checking engine codes but getting Solid constant CEL... DEAD ECU?
I jumped the two pin connection with a solid copper wire. I get constant cel no blink nothing. as soon as i unplug it goes back to normal no cel. Is this a dead ecu or a no problem ecu. I wouldnt be suprised if its dead ecu cuz i get 18mpg city.
Would the car still drive with a dead ecu....any other way to verifiy
Are you doing this with the car started and on?
You should jump the wire with the car off, then turn the key to the run position, but do not start it. Then it will flash the codes, if you have any.
this is with the car off and put in the ON position. so my ecu has no codes? are u sure it just isnt blown ecu. i am hoping so and hoping thats the root of my problems....
Well then.... whats the car doing? Do you get a light while your driving and then when you jump it its still solid, then thats a bad ecu. If you have no codes and you jump it and get a solid then you have no codes.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Well then.... whats the car doing? Do you get a light while your driving and then when you jump it its still solid, then thats a bad ecu. If you have no codes and you jump it and get a solid then you have no codes. </TD></TR></TABLE>
Thats not what i have been reading. I have no codes when driving, but my a/f are whack and i dont know what else it would be. I run so rich you can barely breathe inside the car from emissions. Plus i get 18mpg city 34mpg hw
"Solid Check Engine Light
If the CEL is lit solid and does not blink <u>(after jumping the service check connector on OBD1 )</u> and the car runs poorly the following could be the problem:
* A faulty ECU (means any other component failure other than listed here)
* Poor soldering connections
* Check Sum error
* Faulty program stored in the ROM
* Faulty ROM chip
* Faulty 74HC373 chip"
From http://www.pgmfi.org/twiki/bin/view/Library/CEL
Why does that say the exact opposite of what you said.
* Check Sum error
* Faulty ROM chip
Do you have a wideband or are you looking at the light show a/f gauge?
How does the car run? If its driving fine then you have no problems. If its running like crap then its a bad ecu. Not that hard to tell when an ecu is bad. Try another one and see how it goes.
Someone with obd1 that has NO CODES go jump your ecu and tell me if its solid cel when jumped...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Do you have a wideband or are you looking at the light show a/f gauge?
How does the car run? If its driving fine then you have no problems. If its running like crap then its a bad ecu. Not that hard to tell when an ecu is bad. Try another one and see how it goes. </TD></TR></TABLE>
I have no af gauge. I just know they are wack because i get 200 miles to a 9 gallon tank.
The car drives fast as hell. However, it sputters at complete random when taking off off the line. Only about 2-4 sputters, and only when taking off off the line.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Luserkid »</TD></TR><TR><TD CLASS="quote">Ever heard of a tune up? you know if you keep your car well maintained youll get good gas mileage. try a full tune up. </TD></TR></TABLE>
Done it, slicks.
Well if anyone has a p30 ecu for sale virgin unless its already tuned then im lookin to buy
Done it, slicks.
