Blue Power Project- What should I do next,
<U>This is my 1989 honda civic dx, I bought it as a shell for 200. I had the d15b2 dpfi in the car originally. </U>
(Before I did anything to it)..
OLD MOTOR
After words, swapped motor, rota's,amber corners, hood..
Motor Swap
The b16 I purchased OBD0 cable trans, I put a ACT clutch with GSR flywheel resurfaced. I rebuilt it before putting it in I got new oil pump, new water pump, Skunk2 cam gears, and new timing belt. I also did all new gaskets from top to bottom. I used 90 Da suspenion front and rear discs, I bought EBAY mounts and linkage, PR3 ecu, and Rywire Engine harness great place to buy harness from.
I have been working on this car doing everthing that you see for the last 6 months. its been a long hard road. but I am here.
(Battery Relocation)
Basically I seen people on H-T doing it, and when I did my swap I wanted to free up some space. I got a battery box, and battery cable and moved it to the trunk I want to hook up a kill switch for the track on the back bumper.,
(Wire Tuck)
I removed ac wiring, took headlight wiring and tucked it and the fusebox with all of the wiring I put it under the HVAC case, I like it cause it makes the engine bay look cleaner, next I am going to take all of the vaccum lines away when I get rid of the extra charcoal canister when I hook up the map, on my new T.B. I also plan to get aebs mani to get rid of some other unnesscery vaccum lines.
Obd1 soon. p28 virgin ecu, 4 wire 02 sensor, 68mm t.b. with new map, and 310cc injectors for obd1. I just need the dizzy and the jumper harness
Interior. I used to have tenzo r' racing seats I liked them cause they kinda of look like the stock si's, but then I got another set of seats EP3 si black suede with red stichting (JDM) I have the shift boot and the e-brake boot to match, Also I swapped the crx dash into my civic. I am getting the JDM steering wheel with the red H.
(Next stainless fuel lines...!)
<U>Next things I was thinking about
1. Turbo
2. Paint full dip of this color SI electron blue yes or no?
3. Cage</U>
What do you think of the car and what do you think would be a good next step..
Modified by 4gencivicef9 at 1:38 PM 10/2/2006
Modified by 4gencivicef9 at 1:49 PM 10/2/2006
Modified by 4gencivicef9 at 2:38 PM 10/2/2006
OLD MOTOR
Motor Swap
(Wire Tuck)
1. Turbo
3. Cage</U>
trying to get over 240 HP, on stock motor... aiming low so I wont be disappointed ya know .. Thanks
Trying to get 13' at the track with a turbo ....?
I am hoping to run a high 14 or low 15 stock
Trying to get 13' at the track with a turbo ....?I am hoping to run a high 14 or low 15 stock
yea the exact color..I have the hardner the clear and the paint basically everthing to repaint the entire car...
99 si blue I always liked the si blue so when my buddy had this I thought about it for awhile then decide that I wanted it I am trying to find someone to paint it if you know anyone...
electric blue is from the 99-00 civic? Thats what color my rex will be and i didnt know that was for that year civic, i knew it was close but, good deal... The cars gonna look good i love my b16. keep it up
yea I will have more updates when get new parts...matter of fact got RYWIRE wiring in THANK GOD these guys are great thanks peter and ryan...
also I put the 310..in no bogging Soon obd1
What does the SPSS/GC stand for... also I am trying to get the traction bars I am getting them for the clearance of rad I want half size and I want to stiffen it up...
Yea I was I could afford a k swap, If I go k it is going to be k20R very fast especially in alittle hatch.... to much mods though cutting and rigging not on that level yet lol
yea the color is from the SI's that year it is called electron blue ye it will be sick if you get it done post it up I am trying to see it ...
also thanks I am getting there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gencivicef9 »</TD></TR><TR><TD CLASS="quote">yea the color is from the SI's that year it is called electron blue ye it will be sick if you get it done post it up I am trying to see it ...
I have my engine bay painted the color already, take a look in my sig
</TD></TR></TABLE>I have my engine bay painted the color already, take a look in my sig
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4gencivicef9 »</TD></TR><TR><TD CLASS="quote">What does the SPSS/GC stand for... also I am trying to get the traction bars I am getting them for the clearance of rad I want half size and I want to stiffen it up...
Koni SPSS twin valve shocks, and the Ground Control coil overs. With custom rates. They are available through these guys. They have the best price I've found:
Redshift Motorsports
</TD></TR></TABLE>Koni SPSS twin valve shocks, and the Ground Control coil overs. With custom rates. They are available through these guys. They have the best price I've found:
^XpLiCiTxX^
Oct 28, 2008 08:55 AM
bboylito
Dec 16, 2004 04:26 PM
ElectricBlue13
Sep 4, 2001 01:25 PM
