Help...........don't just look..........im new to this help
New User
Im getting a hold of a 98 GSR....motor tranny.......etc.........can i drop this motor.in a 89 civic hatch......................help....and can enyone tell me how much the swap could run.....me and what other parts....would i need..........
Re: Help...........don't just look..........im new to this help (ElectricBlue13)
i believe you will need axels off of a 90-93teg, a vtec ecu, will def. need the harness's, motor mounts, make sure you got everything you need such as timing belt, water pump, etc. otherwise headaches will arise, while everything is out a upgraded clutch and flywheel would be a good idea.
MysteryWagon
10-31-2001 10:44 AM
