Oil leak under engine
Old Oct 2, 2006 | 07:10 AM
Acco12dv6's Avatar
Default Oil leak under engine
01 accord v6
114,900 miles
Hi All,
I have recently done an oil change on my car and notice some oil leaking under the engine, it is above the oil filter. I had asked a few of my friends and they think its the oil pan gasket seal, but I wanted to get some feedback before I go ahead and fix it.
Thanks.
Old Oct 2, 2006 | 09:07 AM
wrsimmons21's Avatar
Default Re: Oil leak under engine (Acco12dv6)
You may not have made a good seal with the filter to the block. I never do this but you are supposed to take some oil and spread it around the rim on the oil filter before you put the filter on. I would clean everything off and then look for your leak. From what you are saying I don't see why the oil pan gasket is leaking if you say it's from above the oil filter. Just think about what you have changed with the car. If it didn't leak before the oil change then you have good chances it's related to something you did wrong with the oil change. That's not to say that some seal blew or popped out ironically at the same time because it does happen. Good luck.
Old Oct 2, 2006 | 10:14 AM
Acco12dv6's Avatar
Default Re: Oil leak under engine (wrsimmons21)
Well I did my tuneup at a mechanic shop about 3 months ago, not sure if its the front main seal because he said he didn't change that.
mrspeedy69
14
Feb 5, 2012 11:48 AM
z0mby
11
Nov 11, 2011 11:09 AM
chiaxi2002
Apr 9, 2010 08:56 PM
briq4
Honda Civic (2001 - 2005)
11
Aug 17, 2009 04:30 PM
B16CivicEX
May 30, 2006 03:15 PM
