Map Sensort Bracket HELP!!
When removing the brackey on the firewall that holds the MAP sensor, I broke the bolts. they were rusted to the nuts. Can the bolts be replaced and if so, what tool do I ned to get them out of the firewall? If they cannot be replaced, what other options do I have to fix this issue?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeFanatic »</TD></TR><TR><TD CLASS="quote">Just screw it back onto the firewall with self tapping machine screws.</TD></TR></TABLE>
That is a last resort. I would like things as clean as possible.
drill the broken bolts out, or, use an easy out and remove it that way. To drill it out, use a bit thats about 2-3 sizes smaller than the shank. drill carefully all the way through it. you should be able to spin it out, or collapse it and pick it out.
I will try the easy out first as it is in a positon that would force me to remove the intake manifole and no reason to do that if I do not have to.
Westrock2000
May 19, 2003 06:02 AM
