MAP sensor removal
Old Apr 15, 2011 | 11:45 AM
nghtshd88's Avatar
Default MAP sensor removal
I have an 01 4cyl and wanted to know if the screws on the map sensor are phillips head or require some special bit? If so which is it?
Old Apr 15, 2011 | 08:37 PM
uberEFtuner's Avatar
Default Re: MAP sensor removal
Use a good phillips screwdriver and put it on the screw, then tap it pretty hard with a hammer. Then push down while turning counter clockwise.
Old Apr 15, 2011 | 08:58 PM
nus_dogg's Avatar
I believe they're screws; unlike, the TPS where they're riveted to the TB cause Honda doesn't want us to be messing with it.
Old Apr 18, 2011 | 05:05 AM
TouringAccord's Avatar
H-T Order of Merit
I've always found the easiest way to remove those screws is to use an electric drill/driver and set the torque setting really low, then moving it up as needed. After a few seconds they usually back right out without damaging the heads. Just like using an impact on those stubborn nuts/bolts.
Old Apr 18, 2011 | 07:28 AM
zerobacan2's Avatar
I took it out twice, second time the head just became a nice little circle... the crappiest head i ve ever seen... becarefull take in it out
EKMIKEY27
Nov 23, 2010 01:47 PM
cojak23
Jan 7, 2007 04:52 AM
TXGrunt
Dec 3, 2006 09:22 AM
D_CRX_Si
Mar 15, 2006 12:12 PM
Westrock2000
May 19, 2003 06:02 AM
