overheating issue...
is your water pump circulating the coolant properly?
check hoses for obvious leaks, check water pump tell-tale hole for dribbles
remove thermostat, stick it in a bowl of warm water with a thermometer in and keep adding hot water and note the temp at which the stat opens up (although i dont know what temp the EM2 stat is designed to open, somebody else will have to tell you that)
check for leaks going into the bulkhead for your heater box (which is warmed with engine coolant)
check if your coolant temp sensor is ok, check if your dash temp gauge is ok
Although, that is a great way to test your thermostat, I always feel that if you've got it out already that it's a great time to put a new one in. They're not very expensive to replace.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by toyomatt84 »</TD></TR><TR><TD CLASS="quote">Although, that is a great way to test your thermostat, I always feel that if you've got it out already that it's a great time to put a new one in. They're not very expensive to replace.</TD></TR></TABLE>
Quite true, Matt. Ignore my test procedure... if you get the stat out, just replace it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ONLYuk7thGen »</TD></TR><TR><TD CLASS="quote">Quite true, Matt. Ignore my test procedure... if you get the stat out, just replace it.
Hey, it's still a great way to test the thermostat, to see if it truly was the problem.
</TD></TR></TABLE>Hey, it's still a great way to test the thermostat, to see if it truly was the problem.
brought it to the shop down the street and the problem didnt happen while it was there.... my car must be shy. i kinda thought i might have gotten air in the pump when i took off the radiator hose to the block. installing custom cai.
tacoma5050
Honda Civic (2006 - 2015)
Feb 9, 2012 07:59 AM
toohott4handlin
21
Feb 8, 2004 03:47 AM
