ES Shifter Bushings for dc2: 4dr set are "stiffer" than the 2dr set?
Old May 1, 2002 | 08:46 PM
Black R's Avatar
25 Year Member
Default ES Shifter Bushings for dc2: 4dr set are "stiffer" than the 2dr set?
True or False?
Old May 1, 2002 | 09:30 PM
t's Avatar
t
Default Re: ES Shifter Bushings for dc2: 4dr set are "stiffer" than the 2dr set? (Black R)
where did you see that they had a set for 2dr and 4dr?
Old May 1, 2002 | 10:58 PM
sgT's Avatar
sgT
what the hell.... they are THE SAME
Old May 2, 2002 | 05:19 AM
Black R's Avatar
25 Year Member
Default Re: ES Shifter Bushings for dc2: 4dr set are "stiffer" than the 2dr set? (sgT)
Someone said they found a thread where there were different p/n for them and that they upgraded from the 2dr to 4dr bushings cause they were stiffer... Guess not, eh?
Old May 2, 2002 | 05:21 AM
Cosworth's Avatar
Yeah, I was the one thinking that 4dr OE shifter bushing was stiffer than 2dr OE shifter bushing. I don't know about ES shifter bushings... can anyone verify the stiffness of OE bushings??
Old May 2, 2002 | 05:49 AM
Black R's Avatar
25 Year Member
Default Re: ES Shifter Bushings for dc2: 4dr set are "stiffer" than the 2dr set? (Cosworth)
.....yeah ES only has one p/n for shifter bushings on dc2.
I would be interested in hearing about the OE bushings tho..... anyone?
Old May 2, 2002 | 09:56 AM
sgT's Avatar
sgT
what does it matter? the ES bushings are 10 bucks and should be stiffer than any
oem bushing.
Old May 3, 2002 | 08:11 AM
Black R's Avatar
25 Year Member
oem bushing.
$7.
...And that begs the question of whether stiffer is better.
Old May 3, 2002 | 08:14 AM
skafia's Avatar
25 Year Member
noob question: what are shifter bushings? Bushings in the gear box? What's the point of it, and why is more stiff better?
Old May 3, 2002 | 08:42 AM
sgT's Avatar
sgT
Default Re: ES Shifter Bushings for dc2: 4dr set are "stiffer" than the 2dr set? (skafia)
bushings that hold the shift linkage in place.
keeps it from having excessive play front to back and side-side.
Old May 3, 2002 | 08:44 AM
JDM_DOHC_SiR's Avatar
New User
$7.
B&M The "Stiffy"soulution
Old May 3, 2002 | 08:51 AM
sgT's Avatar
sgT
Default Re: ES Shifter Bushings for dc2: 4dr set are "stiffer" than the 2dr set? (JDM_DOHC_SiR)
Too bad they rattle and have been known to break welds on the linkage.
Old May 3, 2002 | 08:54 AM
skafia's Avatar
25 Year Member
Are they hard to install?
Old May 3, 2002 | 08:56 AM
sgT's Avatar
sgT
no
Old May 3, 2002 | 09:16 AM
New User
!!! Wow break welds??! hmm I've used me for over 3+ years without a hick~up..might want to go check mine out
Jabinya
Jan 7, 2007 12:28 AM
elevatethis
23
Dec 28, 2003 01:51 AM
Wazup
Nov 27, 2002 07:20 PM
2k1TypeR0610
Jan 29, 2002 02:51 PM
