my horn doesnt work
Old Oct 1, 2006 | 04:43 PM
hatch96y7's Avatar
Default my horn doesnt work
my horn doesnt honk no more....... and i cant drive with out letting these idiots with out letting them know whats up......... so how do i fix it i tried to put on another horn but nothing....... i want to check the fuse but i cant find it ....... does anybody have any suggestion
Old Oct 1, 2006 | 04:53 PM
hatch96y7's Avatar
Default Re: my horn doesnt work (hatch96y7)
bump
Old Oct 1, 2006 | 04:54 PM
stonedheckler's Avatar
hmmm check the fuses. check your brake lights too cuz the same thing happend in my car and it was the fuse under the hood for the horn and brake lights
Old Oct 1, 2006 | 05:08 PM
hatch96y7's Avatar
Default Re: my horn doesnt work (stonedheckler)
the fuse fro the horn is in the fuse box next to the battery or inside the car
Old Oct 1, 2006 | 05:31 PM
SmogKing's Avatar
There should be only one fuse for the horn, if it's not under the hood then it's under the panel. Also, check the connections from your horn
Old Oct 1, 2006 | 05:45 PM
civic_fan's Avatar
Default Re: my horn doesnt work (SmoGuy)
I'm going on the assumption that your car has SRS based on your username....If it does, there is a possibility that your cable reel is broken. If it breaks or malfunctions, you wont have a horn. This can happen even if you don't have an SRS light on.
Old Oct 1, 2006 | 06:18 PM
x-ray tech's Avatar
do u have a aftermarket wheel? if yes...u might want to redo the wiring.
Old Oct 1, 2006 | 09:16 PM
hatch96y7's Avatar
Default Re: my horn doesnt work (Jdmtion)
yes my srs light is on but i have the stock wheel how do i go about reparing this
Old Oct 1, 2006 | 09:27 PM
civic_fan's Avatar
You will either have to buy a new cable reel (aka: clock spring) or buy a used one. Personally, Id fork out the cash to buy a new one instead of going the used route.
Old Oct 1, 2006 | 09:28 PM
Frozen E's Avatar
H-T White Ops
$100 says that your cruise control doesn't work either.
Your cable reel is jacked up. Order a new one and do a search for "cable reel" in this forum. There's a how-to floating around here somewhere.
Old Oct 1, 2006 | 09:39 PM
hatch96y7's Avatar
Default Re: (IslandSi)
na i dont have cruise contro but having the srs light on does that mean that i have no air bags
Old Oct 1, 2006 | 09:53 PM
Techy's Avatar
Default Re: (hatch96y7)
not necessarily. My SRS light blazed for over a year (CD Player install mishap) on my 95 EX Coupe but when I ran it up under a jeep the air bags deployed just fine. I'd still check your problem ASAP. Mine was just a computer error.
My 96 is actually the 3rd car in a row I've had without a working horn. (It also happens to be my third car so I've never had a horn) I think the actual horn is busted or the wire got disconnected. My 95 had been wrecked 3 times before I had it. No wonder the horn didn't work. Plus the buttons were broke on it anyway. My first car was a 1985 Pontiac Sunbird Hatchback so uhh yeah a 20 year old GM. Of course the horn didn't work. It was amazing enough that the car ran.
Old Oct 2, 2006 | 03:42 PM
hatch96y7's Avatar
Default Re: (Techy)
yeah i noticed the srs light came on after i got a radio installed so shoul i still check the cable reel or something else
jdmouttheass
Honda Civic (2006 - 2015)
Jan 24, 2011 12:22 AM
Bobby808
Apr 10, 2005 11:13 AM
milton
Nov 7, 2004 11:05 PM
Rhythm Racer
11
Jun 27, 2003 10:46 AM
NiCkArInO
May 11, 2003 09:13 AM
