Removing my brake drum cover
Old Oct 1, 2006 | 03:13 PM
Seatown's Avatar
Default Removing my brake drum cover
In my Chilton it says, " Screwing in two bolts and tightning alternately will press off the brake drum". What type of screws are they refering to, the picture shows some type of socket wrench but where do I purchase these screws?
I was getting ready to take pictures of my drum brake/wheel cylinder but couldn't get my got damn drum off.
Old Oct 1, 2006 | 03:29 PM
Suck my DX's Avatar
Default Re: Removing my brake drum cover (Seatown)
tap it a few times with a hammer
Old Oct 1, 2006 | 03:30 PM
Seatown's Avatar
Default Re: Removing my brake drum cover (Suck my DX)
^What about the screws?
Old Oct 1, 2006 | 03:36 PM
Suck my DX's Avatar
are you referring to the rear drums?
there are no screws holdoing it on...its a tight fit they slip on...first try pulling it and if it dont budge,give it a couple lil smacks and it should pop right off
Old Oct 1, 2006 | 03:48 PM
Fobtions's Avatar
yes u can use a regular 10mm bolt in the threaded holes of the drum.
Works good
Old Oct 1, 2006 | 04:01 PM
civicflow's Avatar
Default Re: Removing my brake drum cover (Fobtions)
when i was in school I couldn't get my drivers side brake drum cover off. Even my teacher couldn't get it off. We tried beating on it and also heating it up but never came off. Didn't try driving bolts into it tho. That should do the trick as I did it on my buddies crx.
Spikey640
May 18, 2008 09:09 AM
94c1v1cex
May 25, 2007 11:04 AM
dwarrick
May 19, 2006 10:45 AM
GUNNER666
Oct 19, 2004 06:45 AM
