Questions about setting up a oil catch can?
I dont know if I am posting in the correct forum but I have a couple questions. Ive been wanting to do a catch can for the block, since i currently only have -10 off the valve cover. I want to do -10 for this setup aswell but need to know what size the fittings are going to be for the block? They need to be AN threads to be able to hook up AN fittings and all. Hope someone can help. Good day -- Alex
You prob want to look more directly towards the all motor tech
but there is a oem part you can order that will thread in and has a reg fitting off it it that u can convert to AN
its off of a prelude serch h22 breather or something good luch or just make your own with a drill and a drill you plug thats in there and get and an fitting and stick it in, good luck
you can get a brass fitting straight from HONDA or a great TUNER SHOP that goes into the factory freeze plug inb the back of the B20 block - then run the lines to the can you choose. I would say -12 min for the valve cover
rock on. Since im going to be seeing these guys from this GREAT TUNER shop i know i will just get em from him. Thanks
whatcivic
Jun 14, 2010 01:36 PM
