can these civics hold H22, B18-R, B16-R
Old May 1, 2002 | 08:02 PM
wizzards581's Avatar
Default can these civics hold H22, B18-R, B16-R
if so.. pics.? or
Old May 1, 2002 | 08:07 PM
Malgerus's Avatar
Default Re: can these civics hold H22, B18-R, B16-R (wizzards581)
Old May 1, 2002 | 10:25 PM
Default Re: can these civics hold H22, B18-R, B16-R (89_Y_49)
im talkin bout these genss........ the ef.....
Old May 1, 2002 | 10:46 PM
MysteryWagon's Avatar
genssssssssss, yes they will, with the help from a kit on the Bseries, and some engine work for the H22a but not recomended for more than street driving and straight line racing.
Old May 2, 2002 | 03:29 AM
FourthGenHatch's Avatar
An EF with an H22 will have trouble turning, so unless it's for straightline drag racing only I wouldn't get one.
Old May 2, 2002 | 06:44 AM
JalopySiR's Avatar
Default Re: can these civics hold H22, B18-R, B16-R (FourthGenHatch)
Well the B18C5 and the B16B are very tall motors. Much more so that say, a regular B16, or an LS motor. They will fit with a HASport kit, but due to thier height they will either rub the hood, or if shimmed down, be dangerously close to the ground. There is no bolt-in kit for an H/F series into an EF as of yet. It can be done but it requires welding and alot of body work. If you are going for a straight drag car, the H22 is hard to beat for the money, if not I would not put it into an EF chassis. Hope that helped.
Old May 2, 2002 | 09:11 AM
91CivicSi's Avatar
Default Re: can these civics hold H22, B18-R, B16-R (JalopySiR)
I was under the impression that the only difference in height among B-series motors was about 3mm in deck height between the B16 and B18/B20?
Old May 2, 2002 | 09:30 AM
GraphiteAccord's Avatar
Default Re: can these civics hold H22, B18-R, B16-R (91CivicSi)
B16B, B18C5r, B18C1, B18c3, B18A, B18B, B20 etc all have the same deck hieght. The only small dec k motors are B16's, ZC's, and D series.
Old May 2, 2002 | 09:31 AM
Default Re: can these civics hold H22, B18-R, B16-R (GraphiteAccord)
Also, its a 7mm deck difference, not 3mm.
89crxsiVT
May 3, 2007 11:13 PM
TheDelSlo
Oct 18, 2005 11:36 AM
why2nite
Nov 17, 2004 03:44 PM
onemisledyuth
Mar 6, 2004 03:17 PM
