Are d-series engines non-interference?
Old Sep 30, 2006 | 09:35 PM
gurippugasuki's Avatar
Default Are d-series engines non-interference?
Old Sep 30, 2006 | 09:57 PM
Tippyman's Avatar
Depends on what you're talking about. Mount wise, they will all bolt in no problem. (with the exception of differnt gen's t-belt mount. hybrid of both car's required.)
Wiring differneces are the only real diff I guess. Any time you change OBD you're gonna have electrical diff's.
Old Sep 30, 2006 | 10:18 PM
Default Re: (Tippyman)
I am referring to the head design.
Old Sep 30, 2006 | 10:36 PM
t25d16a6's Avatar
Default Re: Are d-series engines non-interference? (gurippugasuki)
im pretty sure they are interference
Old Sep 30, 2006 | 10:40 PM
saaron34's Avatar
Default Re: Are d-series engines non-interference? (t25d16a6)
I believe D series are not the non-interference design. Your timing belt goes, now most of your valves are bent too.
ford escorts 91-96 are non-interference design. I was so relieved to know that when my belt snapped...
Old Sep 30, 2006 | 10:45 PM
jisu009's Avatar
Default Re: Are d-series engines non-interference? (saaron34)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by saaron34 &raquo;</TD></TR><TR><TD CLASS="quote">I believe D series are not the non-interference design. Your timing belt goes, now most of your valves are bent too.
ford escorts 91-96 are non-interference design. I was so relieved to know that when my belt snapped...</TD></TR></TABLE>
well....
yes, if your belt snaps...your valves are probably bent.
That means the engine is an "interference" design.
To answer your question, yes the are interference engines.
Old Sep 30, 2006 | 10:56 PM
Default Re: Are d-series engines non-interference? (jisu009)
Hmmm...I see. I was hoping they weren't since I find so many deals on EF's with snapped belts. Then again, it's a perfect excuse for a swap right ? Thanks for the info. That's why I love 4ag's and BMW M42's&lt;---non-interference! BTW I'm on the lookout for an SI. Someone beat me to a lien sale one today. It was at a tow yard and all it needed was a hood! Clean title for $600!!!! Oh well, I'm sure I'll find another deal...
Old Oct 1, 2006 | 12:01 AM
UKjeff's Avatar
The belt snapped on my D16A9, I was at about 4k at 70 mph.
No damage to the valves what so ever.
Also know of a few other D16 EF's that have had belt snaps and no problems.
Old Oct 1, 2006 | 12:16 AM
njn63's Avatar
Default Re: Are d-series engines non-interference? (UKjeff)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UKjeff &raquo;</TD></TR><TR><TD CLASS="quote">The belt snapped on my D16A9, I was at about 4k at 70 mph.
Also know of a few other D16 EF's that have had belt snaps and no problems.</TD></TR></TABLE>
It happens but the engine is an interference engine still so if you snap a timing belt you should always check if the valves are bent. At the very least do a compression test after putting the new belt on.
Old Oct 1, 2006 | 01:25 PM
suspendedHatch's Avatar
Default Re: Are d-series engines non-interference? (njn63)
Interference engines are generally superior to non-interference engines. The engines are built to tighter specs and are optimized for max performance.
Old Sep 22, 2012 | 10:25 PM
scarab280ze's Avatar
Thanks I needed that info too
Old Sep 23, 2012 | 12:12 AM
91turbosohc's Avatar
udog1125
Sep 14, 2016 03:15 AM
BanEL
Feb 18, 2010 10:29 AM
13g-crx
Mar 8, 2007 02:13 AM
seerx
Nov 30, 2003 07:15 PM
HaTcH_BmX
Jun 1, 2003 03:57 PM
