obd-0 motor going into my 98 civic ex ek
Old Sep 30, 2006 | 01:05 PM
h22civicek's Avatar
Default NEED HELP obd-0 motor going into my 98 civic ex ek
i just bought a ls vtec but its obd-0 what do i have to do for wireing , also how to convert to obd1 if the motor is obd0- and the car is obd2
Old Sep 30, 2006 | 01:10 PM
Luserkid's Avatar
Default Re: NEED HELP obd-0 motor going into my 98 civic ex ek (h22civicek)
Easiest thing to do is get gut your internals from your dist (everything down to the shaft) and place it in the dist. that you get. Now its obd2. Next get an integra obd2 alternator and place all your sensors on the new motor. Next change out your injectors onto the motor (unless its coming with aftermarket, then put in new injectors clips). Now your running your stock harness. Next get a jumper harness and run the obd1 ecu. there you go.
Old Sep 30, 2006 | 02:55 PM
noz79's Avatar
http://www.boomslang.us/ Try them out, its seems to be what your looking for.
Old Oct 1, 2006 | 09:29 AM
h22civicek's Avatar
Default Re: NEED HELP obd-0 motor going into my 98 civic ex ek (Luserkid)
yea but what do i do about the knock sensor , and there is a couple more taht have plugs on the wireing harnees but no lace to plug in on the motor
Old Oct 2, 2006 | 12:01 PM
h22civicek's Avatar
bump
Old Oct 2, 2006 | 01:11 PM
Luserkid's Avatar
Default Re: (h22civicek)
If your going to run a chipped ecu then dont worry about the knock sensor.
Old Oct 3, 2006 | 09:59 PM
VtecnTurbo's Avatar
Default Re: (Luserkid)
obd2 has more sensors then obd1 so you will have a few plugs just un plugged. obd1 ecu does not look for them so you will not have a check engine light.
Old Oct 4, 2006 | 07:51 AM
h22civicek's Avatar
Default Re: (VtecnTurbo)
o alright thanks guys
ShagPower
Jul 1, 2008 01:30 PM
Anti-Drama Queens
Sep 29, 2007 05:51 PM
ww91crx
Jan 26, 2006 05:41 AM
superfuji57
Mar 15, 2004 02:23 PM
