help!!! rpm signal disappear after 6500rpm
Old Sep 30, 2006 | 10:16 AM
JDM_Risa's Avatar
Default help!!! rpm signal disappear after 6500rpm
anyone care to shed some light on this subject long story short
top my car out in 5th gear at 9500rpm doing 150mph+
my distributor took a crap due to the rotor bolt getting loose and moving around in there bent all the terminals inside complete deformed rotor...bolt got sandwich between two terminals on the ignitor...blew out a fuse and crack the ignitor.... spun all my bearings in the process
replace all the bearings car runs like a champ beside the rpm signal once i hit 6500 it shoots all the way to zero and all over the place...but car still pulling smoothly...i just like to know what rpm i am at therefore...
so i went head and replace the dizzy shaft new msd cap and rotor...
i am running an external SS blaster
any idea whats wrong with it?
Old Sep 30, 2006 | 10:39 AM
lsturbo9's Avatar
Default Re: help!!! rpm signal disappear after 6500rpm (JDM_Risa)
EG,EK,DC?
CHECK YOUR O2,VSS,ALT WIRES THEY COULD HAVE SHORTED
Old Oct 1, 2006 | 10:04 AM
JDM_Risa's Avatar
Default Re: help!!! rpm signal disappear after 6500rpm (lsturbo9)
its '01 Acura Integra Type R DC2... sorry to sound like a newb how do you go upon checking these wires....i am gonna put my friend '01 GSR dizzy on my car later today gonna see how that goes....if doesn't change anything i swear i am clueless
i am pretty sure its gotta be a short becuz after it didn't start anymore there was a bolt that made two terminals contact and blew out a fuse
TTT anymore help
Old Oct 1, 2006 | 10:14 AM
lsturbo9's Avatar
check for eny fried wires
Old Oct 1, 2006 | 10:20 AM
BoostedEG6's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsturbo9 &raquo;</TD></TR><TR><TD CLASS="quote">EG,EK,DC?
CHECK YOUR O2,VSS,ALT WIRES THEY COULD HAVE SHORTED </TD></TR></TABLE>
It is none of those wires...... they have nothing to do with the RPM signal.... look on your distributor and look for the RPM signal wire. I want to say its a pink wire but im not 100% sure right off the top of my head... but follow that wire and make sure there is nothing wrong with it.... it could also be the distributor itself, try your friends and see what happens it only takes a few mins to trade them out
Old Oct 2, 2006 | 03:23 AM
JDM_Risa's Avatar
Default Re: help!!! rpm signal disappear after 6500rpm (BoostedEG6)
i will keep everyone informed thats helping me out...thanks my friend was busy today...haven't got to it yet....i am gonna get an ohm meter and test each wire to see the resistance as soon as i learn how to use it another friend of mine was suppose to help me do that never called back either....after this problem fixed i got another problem to resolve....so many electrical problem
Old Oct 2, 2006 | 04:28 AM
civicsit's Avatar
at one time my tach was doing the same thing. you may want to have the igniter looked at to see if it is bad. once i had put a new igniter in it was fine after that.
good luck
Old Oct 2, 2006 | 09:58 AM
JDM_Risa's Avatar
Default Re: help!!! rpm signal disappear after 6500rpm (civicsit)
i tried that already. third ignitor...replace SS coil blaster replace spark plug wires...coil blaster wires....the shaft inside the distributor...its driving me insane
Old Oct 2, 2006 | 10:06 AM
BoostedEG6's Avatar
have you replaced the whole distributor? or tried another one that is working on another car?
where all the parts new or used that you replaced everything with?
Old Oct 2, 2006 | 11:30 AM
turbotime's Avatar
Its the ignitor- thats the ONLY thing that sends the RPM signal to the tach.
Are you using OEM ignitors? MSD? Advance Auto? If they are OEM are they new? or used?
Old Oct 2, 2006 | 08:51 PM
JDM_Risa's Avatar
Default Re: (turbotime)
coil blaster new, cap new, rotor new...msd parts.....ignitor used...from 2 other dizzy i tried that i knew were running...
had my friend with an 01 gsr come over today...swap his dizzy car rev pass 6500 like a champ...
so i thought i fried my coil blaster positive and negative wires so i then replaced it with slightly thicker gauge wire...and took the car for a spin rpms agains disappear i am just gonna purchase a dizzy and convert it for msd tired of dealing with the dizzy problem
thanks to everyone that took the time to help me out greatly appreciated
wagovan guy
Jan 11, 2015 12:18 PM
nicoya_hyphy@yahoo.com
Apr 9, 2009 06:23 AM
Extreez
Jan 3, 2007 04:33 PM
jakedoza
10
Jun 13, 2005 01:43 PM
b18cEF9
Aug 27, 2004 11:21 AM
