timing service connector
Old Sep 30, 2006 | 08:28 AM
t25d16a6's Avatar
Default timing service connector
i bought a 91crx hf with a b18b1 motor and i went to set the timing and when i jumped the service connector i noticed no change in idle or anything like it did nothing and then i forgot to take the paperclip out and drove it like that...and it drove normal....does anybody know where the wires lead from the clip....like to the ecu or what?....cuz i know ive jumped the connectors in the past and you can definately notice a change....is it safe to just put the dizzy in the middle...is that close? any help would be appreciated..... thanks
Old Sep 30, 2006 | 07:04 PM
t25d16a6's Avatar
Default Re: timing service connector (t25d16a6)
bump
Old Sep 30, 2006 | 07:16 PM
SmogKing's Avatar
Your good, your timing should be close to specs.
Old Oct 1, 2006 | 05:47 AM
t25d16a6's Avatar
Default Re: timing service connector (SmoGuy)
is it normal to be able to drive around with the connector jumped and notice no difference at all?
Old Oct 1, 2006 | 08:20 AM
HondaHeddie's Avatar
I am curious too
What does that jumper do?
I could not see any difference in setting the time or driving
Old Oct 1, 2006 | 08:44 AM
4dOoR-Ex's Avatar
ok hold one... this is my first time hearing about a conector and timing,( not jacking the post ) can some one please explain///
Old Oct 1, 2006 | 09:36 AM
Default Re: (4dOoR-Ex)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4dOoR-Ex &raquo;</TD></TR><TR><TD CLASS="quote">ok hold one... this is my first time hearing about a conector and timing,( not jacking the post ) can some one please explain///</TD></TR></TABLE>
Get a Helms manual, then you will know all. helmsinc.com
there is a connector behind the glovebox that you jumper when setting the time.
I assume it is to keep the ecu from reacting to your adjustments, but I havent seen a difference.
dsmIA
Jul 12, 2005 08:11 PM
CIVIC96DXcp
Apr 19, 2005 07:47 PM
ewn1603
Sep 25, 2004 06:22 AM
c-way
Jun 11, 2004 04:16 AM
Nextelbuddy
Mar 30, 2004 10:09 AM
