tires worn. camber or toe
Old Sep 28, 2006 | 07:53 AM
VtecFreePrelude's Avatar
Default tires worn. camber or toe
only two of my tires are worn though.
front passenger and rear drivers side
would that be a camber issue or a toe?
i would think toe would cause both sides to go out but maybe i'm wrong
Old Sep 28, 2006 | 08:19 AM
Hawkze_2.3's Avatar
Default Re: tires worn. camber or toe (VtecFreePrelude)
Old Sep 28, 2006 | 08:23 AM
M@'s Avatar
M@
Default Re: tires worn. camber or toe (Hawkze_2.3)
i agree ^^
I actually can't keep my car from eating tires
Old Sep 28, 2006 | 08:38 AM
phatsindabuildin's Avatar
If it's a camber issue it won't be noticable. Get an alignment and ZERO out the toe.
Old Sep 28, 2006 | 08:39 AM
petern101's Avatar
Default Re: tires worn. camber or toe (M@)
^do you get alignments regularly? if they are getting off.
then you might either have some worn bushings, or something isn't tight on your suspension
Old Sep 28, 2006 | 08:40 AM
john d
Guest
Posts: n/a
Default Re: tires worn. camber or toe (petern101)
y dont u go get an alignment and find out
Old Sep 28, 2006 | 08:43 AM
98vtec's Avatar
moderator emeritus
toe kills tires 10x more than camber will
Old Sep 28, 2006 | 08:51 AM
thanks guys i'm trying to find time to get one but it confused me cause of the two different tires.
Old Sep 28, 2006 | 10:18 AM
MyLilCivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VtecFreePrelude &raquo;</TD></TR><TR><TD CLASS="quote">only two of my tires are worn though.
i would think toe would cause both sides to go out but maybe i'm wrong</TD></TR></TABLE>
If the tire wear is coming from the inside of the tire it is the camber. The toe usally messes up the whole tire and it gets really choppy. If i were you i would just get a full alinment its like 75 bucks unless you got the hook up
Old Sep 28, 2006 | 10:20 AM
98vtec's Avatar
moderator emeritus
Default Re: tires worn. camber or toe (MyLilCivic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyLilCivic &raquo;</TD></TR><TR><TD CLASS="quote">If the tire wear is coming from the inside of the tire it is the camber. The toe usally messes up the whole tire and it gets really choppy.</TD></TR></TABLE>
not really.
Old Sep 28, 2006 | 10:24 AM
soundbomber's Avatar
Default Re: tires worn. camber or toe (98vtec)
camber good
toe bad
Old Sep 28, 2006 | 11:12 AM
LudeBehavi0r's Avatar
Yea, depending on how much negative / \ or possitive \ / to you have will effect which part of the tire gets work.
Negative camber and lots of negative (and or possitive) toe will deff dominate the inside of your tires. The camber isnt the bad part, the toe is what either makes your car plow / \ (- toe) or scoop/shovel \ / (+ toe)
The little diagrams i drew were assuming you were standing on your hood looking forward and down over your wheels.
Old Sep 28, 2006 | 12:09 PM
my9thtry's Avatar
Default Re: tires worn. camber or toe (phatsindabuildin)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phatsindabuildin &raquo;</TD></TR><TR><TD CLASS="quote">If it's a camber issue it won't be noticable. Get an alignment and ZERO out the toe.</TD></TR></TABLE>
actually zeroing out the toe is going to cause a problem. i think the factory setting are around 1.5 +or- .5 degrees . you need some toe zero will just eat up your tires
Old Sep 28, 2006 | 12:13 PM
Care to elaborate aside from what the factory settings are?
Old Sep 28, 2006 | 12:26 PM
CGags13's Avatar
Default Re: tires worn. camber or toe (my9thtry)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by my9thtry &raquo;</TD></TR><TR><TD CLASS="quote">actually zeroing out the toe is going to cause a problem. i think the factory setting are around 1.5 +or- .5 degrees . you need some toe zero will just eat up your tires</TD></TR></TABLE>
the closer to zero (total toe) is good...i have stock civic settings in front of me, even though a different car, it still applies:
front: -0.12 - 0.12
total front toe: -0.24- 0.24
rear is less -0.04 - 0.08
total rear toe: -0.08 - 0.16
i ended up getting my fronts to -.02 and -.01 and my rears at .02 and .00,
resulting in total front at -0.03 and rear 0.02
you dont really need to toe them in unless you are racing and prefer a quicker turn in...close to zero as possible for street manners
camber is a preference also..running a little negative esp...up front will help out..think about when you romp on it your suspension lifts up front gaining positive, so adding some negative helps..i ended up setting my front on my car 3/10ths a degree less in the back than front...(only running 1 degree front) stock on the civic is -2.0 to 0 but several friends and myself agreed on -1 for the street after driving around with -2 for a week and havent noticed a difference...
sorry if i rambled...alignments are my new joy..after driving for a year with a **** poor one
Old Sep 28, 2006 | 12:29 PM
petern101's Avatar
actually you are VERY VERY WRONG!!
front is supposed to be within +- .08 degrees with total toe within .16 degrees up front
rear is 0 to .16 degrees each side with total rear toe at 0 to .32 degree.
a little far off from what you stated eh?
Old Sep 28, 2006 | 12:33 PM
CGags13's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by petern101 &raquo;</TD></TR><TR><TD CLASS="quote">actually you are VERY VERY WRONG!!
a little far off from what you stated eh?</TD></TR></TABLE>
pwwnnd!!!
Old Sep 28, 2006 | 01:25 PM
roller3804's Avatar
I work at a honda dealer and align honda cars all the time.
preludes are 0.00 in the front and 0.08 in the back if they are DEAD on
And to OP its def the toe..I have wayyy negative camber but my toe is aligned correctly and my tires are fine
Old Sep 28, 2006 | 02:30 PM
Default Re: tires worn. camber or toe (roller3804)
wtf??
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by roller3804 &raquo;</TD></TR><TR><TD CLASS="quote"> work at a honda dealer and align honda cars all the time.
preludes are 0.00 in the front and 0.08 in the back if they are DEAD on </TD></TR></TABLE>
yep. my rears were aligned to 0.05, fronts are 0.00
Old Sep 28, 2006 | 08:44 PM
petern101's Avatar
lol i wish i could get dead zero. i always have just a little, and its within honda specs so i just drive
Old Sep 29, 2006 | 08:21 AM
DC5 Demon's Avatar
I go threw a set of tires in about 3 months i lowered my car, lol my dumbass never got aligned yet but i always thought it was camber until now. im glad to know that it's toe and I probably won't have to get a camber kit. Im on tokico 5-way struts and ground control coil overs low as you can go in the front and equal in the rear, but it still has about an inch to go.
cilvia
Mar 23, 2011 05:28 PM
jordancrockett
Dec 7, 2008 12:54 AM
Nicks95GSR
Dec 22, 2006 07:56 AM
doodooheadfart
Suspension & Brakes
Jan 16, 2006 09:01 AM
vsm dc4
Jan 31, 2005 11:01 AM
