how do i hook this radio up?
Old Sep 28, 2006 | 03:00 AM
an2ny888's Avatar
Default how do i hook this radio up?
got this unit cheap, problem is it didn't come with sockets and it doesn't plug into the stock integra harness. anybody installed this before?
Old Sep 28, 2006 | 08:16 AM
kroze's Avatar
Default Re: how do i hook this radio up? (an2ny888)
any 98+ honda/acura should work with it.
Old Sep 28, 2006 | 08:17 AM
kroze's Avatar
Default Re: how do i hook this radio up? (kroze)
if you don't have 98+honda/acura, go to installdr.com and buy the adapter harness.
Old Sep 28, 2006 | 08:33 AM
B18C_EJ8's Avatar
Alright.. As stated above, it does look like a 98+ reverse harness will plug into the top unit. However, you're going to need to find the jumper cable that attaches the slave unit to the main tuner module... That is probably going to be the tricky part...
Old Sep 28, 2006 | 08:57 AM
kroze's Avatar
Default Re: (B18C_EJ8)
just go to ebay or installdr and get the slave cable that connect the top to the bottom unit.
Old Sep 28, 2006 | 07:54 PM
an2ny888's Avatar
Default Re: (kroze)
i have the slave unit cable, problem is the 98 + integra cable is only 16 pins, my unit has 20 pins, plus they're not all the same size (the outer ones are bigger).
Old Sep 28, 2006 | 08:14 PM
kroze's Avatar
Default Re: (an2ny888)
i don't know what to tell you. but they only make 1 (One) harness and that's made specifically for 1998+ models honda & acura. Or else they would have make 2 different one wouldn't they?
Old Sep 29, 2006 | 12:08 AM
turboekcivic's Avatar
Default Re: (kroze)
yeah im pretty sure kroze is right
Old Sep 29, 2006 | 07:21 AM
an2ny888's Avatar
Default Re: (turboekcivic)
guys could you please count the number of pins on your 98+ sockets? i'd appreciate it, tnx
Old Sep 29, 2006 | 09:12 AM
fcm's Avatar
fcm
Old Fart
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by an2ny888 &raquo;</TD></TR><TR><TD CLASS="quote">guys could you please count the number of pins on your 98+ sockets? i'd appreciate it, tnx</TD></TR></TABLE> And offset by the looks of it, a clearer pix of the plug would help, but it does not look like any Honda/Acura plug I have ever seen, are there any model numbers on them, [stickers], maybe JDM?94
Old Sep 29, 2006 | 04:34 PM
94_DC4's Avatar
Default Re: (fcm)
Gathers is JDM. Someone correct me if I am wrong but doesn't/didn't Alpine make the Gathers units in Japan.
Old Sep 29, 2006 | 04:47 PM
an2ny888's Avatar
Default Re: (fcm)
the head unit is oem honda for the type r, it's a pioneer, while the gathers md player is made by alpine. i'll take a close up pic of the plug later
Old Sep 30, 2006 | 08:02 AM
an2ny888's Avatar
here's a better pic of the socket
Old Sep 30, 2006 | 08:50 AM
fcm's Avatar
fcm
Old Fart
I have done a few Type Rs and they have all had the same plug as the rest of the tegs, this unit may have had an off board amp and the plug your missing is the jumper that went between the HU and the amp and the amp has the Honda/Acura plug on it, that would account for the extra pins, [power and ground for amp], although the HU also has a heat sink so I would assume it also has an amp built in. 94
ravinaziankid
Audio / Security / Video
10
Jan 27, 2011 10:08 AM
96 EX
Jul 24, 2008 02:40 PM
revhi
Feb 16, 2006 01:16 PM
