jdm p13 ecu
Old Sep 27, 2006 | 11:16 PM
darkstar1440's Avatar
Default jdm p13 ecu
If I put the jdm p13 ecu in my h22a1 prelude will my car rev out higher or get more fuel essentialy make it quicker?
Old Sep 28, 2006 | 12:12 AM
y0whuddupb's Avatar
Default Re: jdm p13 ecu (darkstar1440)
no. p13 is a p13. jdm or usdm. if it were chipped...possibly. otherwise a stock p13 is the same as any stock p13.
Old Sep 28, 2006 | 05:48 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: jdm p13 ecu (y0whuddupb)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by darkstar1440 &raquo;</TD></TR><TR><TD CLASS="quote">If I put the jdm p13 ecu in my h22a1 prelude will my car rev out higher or get more fuel essentialy make it quicker?</TD></TR></TABLE>
HaHa, I will trade you straight up my JDM p13 for your USDM p13...Plus give you 20 dollars (if its in great working condition).
Old Sep 28, 2006 | 07:38 AM
petern101's Avatar
Default Re: jdm p13 ecu (AnthonyG2003)
actually it will make you go slower
they have different fuel maps but its made for a jdm engine. not yours
and there's a speed limit governer of ~117mph
Old Sep 28, 2006 | 05:35 PM
bb4socal's Avatar
tHE JDM ecu has a governor. Its at 120 mph. The USDM doesnt. But he is right, the fuel maps are different. Im sure not by much, also ive been told that the rev on the JDm is higher. juss search and youll find answers.
Old Sep 28, 2006 | 06:03 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: (bb4socal)
the rev is not higher...and the speed governor is at 118mph.
Old Sep 28, 2006 | 08:06 PM
JasonST's Avatar
Default Re: (AnthonyG2003)
Yeah on mine revs cut out at around 7800, speed govenor was close to 120, probly 118, when I tried seeing exactly where the govenor was, and yeah the fuel maps are different, cause the jdm engine has higher compression and is meant to run higher octane fuel. Just stick with ur usdm p13 or get a chipped ecu and tune it.
Old Sep 28, 2006 | 08:37 PM
petern101's Avatar
Default Re: (JasonST)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JasonST &raquo;</TD></TR><TR><TD CLASS="quote">Yeah on mine revs cut out at around 7800, speed govenor was close to 120, probly 118, when I tried seeing exactly where the govenor was, and yeah the fuel maps are different, cause the jdm engine has higher compression and is meant to run higher octane fuel. Just stick with ur usdm p13 or get a chipped ecu and tune it.</TD></TR></TABLE>
actually it displays 7800 on your tach. but its 7600
and there's always this thing how ppl say 117, 120 etc etc.
its just 190 km/h which is like 118ish converted over (just to settle the debate)
pkolaboy
Apr 15, 2008 08:31 PM
ludesrv
Mar 12, 2006 04:47 PM
blackdelslo
Jun 20, 2004 10:10 AM
shift6th
Honda S2000
Apr 4, 2004 07:32 PM
Jago
Oct 18, 2002 11:32 AM
