Honda S2000 Honda S2000
jdm ecu
Old Apr 3, 2004 | 10:55 PM
shift6th's Avatar
Default jdm ecu
I was wondering if a reprogrammed JDM ECU would be benifical?
Thanks in advance
Old Apr 4, 2004 | 12:37 PM
evil vapor's Avatar
Default Re: jdm ecu (shift6th)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shift6th &raquo;</TD></TR><TR><TD CLASS="quote">I was wondering if a reprogrammed JDM ECU would be benifical?
Thanks in advance </TD></TR></TABLE>
reprogramed to what map?
Old Apr 4, 2004 | 07:29 PM
spirit R
Guest
Posts: n/a
Default Re: jdm ecu (vapor)
Techtom says the JDM and USDM maps are the same however the JDM ecu has the 101 RON or 96 octane maps along with possibly a low temp high octane map these are most likely present but locked in the USDM version. there going to look into it however it would be of little use.
Also the JDM ECM is likely to have the 200 kph aka 112 mph fuel cut off. I am almost certain since one of the catalogs I have a speed cut defenser listed.
Old Apr 4, 2004 | 07:32 PM
evil vapor's Avatar
Default Re: jdm ecu (Duke Togo)
don't forget immobilizer not used in the jdm ecu.
pkolaboy
Apr 15, 2008 08:31 PM
Revi
Oct 11, 2006 03:15 PM
ludesrv
Mar 12, 2006 04:47 PM
