Crazy tach, spark cutting out, car turning off
Old Sep 27, 2006 | 01:08 PM
CGags13's Avatar
Default Crazy tach, spark cutting out, car turning off
OK so John's car (jd3jdm) is being gay...heres the symptoms
anytime you give more than 1/2 throttle, the tach goes crazy and then spark is cut out like its hits a rev limiter
on the highway the other night, the tach was going back and forth and john could barely touch the gas without the spark getting cut (engine just sputters and dies)
randomly the thing will just shut off while cruising
here's what we have done so far:
changed out the computer (p28) with my computer(p28) of course we swapped the PROMs too...his computer ran fine in my car... but his car still had the problem..so its not computer related
hes running a h23 ignition with the external coil...
What should we check..besides grounds...
can we eliminate the coil b/c if we had a bad coil then the damn thing wouldnt even start correct??
thanks guys...were trying to get this $20,000 pos to run...I WANNA GO RACING ALREADY!
Old Sep 27, 2006 | 01:43 PM
CGags13's Avatar
Default Re: Crazy tach, spark cutting out, car turning off (CGags13)
come on rectoids...think here..cause im out
Old Sep 27, 2006 | 04:19 PM
JasonST's Avatar
Sounds like it's probly the ignitor inside the dizzy, also check all ur grounds, I had a problem just like this and turned out to be the weirdest thing of all. I had so much corrosion on my battery terminals, fixed that and that problem went away. Also, what rpm does it cut out at, and are u getting any cels?
Old Sep 27, 2006 | 05:39 PM
CGags13's Avatar
Default Re: Crazy tach, spark cutting out, car turning off (JasonST)
no cels....it cuts out well under 5000 rpm when you go more than 1/2 half throttle...on the highway it cuts out at cruising speed between 3000-4000 rpm
the bro y yo really think its grounds..guess we'll have to get our investigate on this weekend
Old Sep 27, 2006 | 07:10 PM
JasonST's Avatar
Yeah grounds would be a good thing to look for, also make sure the connections on ur ignitor are nice and tight, the tach gets its signal from the ignitor.
Old Sep 27, 2006 | 09:23 PM
Rosko's Avatar
have you replaced the main relay? that sounds like the prob to me.
doubt its the battery terminals cuz that wouldnt make the car die.
Old Sep 28, 2006 | 12:18 AM
y0whuddupb's Avatar
Default Re: Crazy tach, spark cutting out, car turning off (Rosko)
sounds like a bad dizzy. my rpm tach was jumpy. and the shaft had major play.
Romeo32004
Nov 16, 2007 08:44 AM
Project X
Sep 15, 2007 02:56 PM
starchland
Aug 28, 2004 08:05 PM
nd8ch
19
Nov 2, 2003 10:37 PM
patastinky
Jan 27, 2003 11:33 PM
