b16a or b18c1 head for build which is better??
Old Sep 27, 2006 | 12:59 PM
Rhymenoceros's Avatar
Default b16a or b18c1 head for build which is better??
Ive heard the b16a has more air flow.. I just bought a b18c1 long block.. but i have a b16a complete with me right now.. I was thinking about putting the jdm b16 head on my gsr block.. But Im going to build it first..
Any recommendations o which head i should build.. by the way Im not porting it..
Old Sep 27, 2006 | 01:15 PM
alterdcreations's Avatar
Default Re: b16a or b18c1 head for build which is better?? (E1337ulga)
gsr head has a better valve movment i think(more at a 90 degree angle that b16a i think)
also it will raise your compression over the b16 head
Old Sep 27, 2006 | 01:35 PM
Default Re: b16a or b18c1 head for build which is better?? (alterdcreations)
thanks man..
o ok.. i think im am going with buddy club springs and retainers... maybe supertech vavles not sure on that..
but gsr cool.. that will be easier to sell my b16 complete with a b16a head on it rather then a gsr.. awesome thanks..
Old Sep 27, 2006 | 01:44 PM
xDicktonesx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by alterdcreations &raquo;</TD></TR><TR><TD CLASS="quote">gsr head has a better valve movment i think(more at a 90 degree angle that b16a i think)
also it will raise your compression over the b16 head</TD></TR></TABLE>
the only diff is the combustion chambers and the bolt pattern on the intake manifold side. '
gsr raises your compression .2
harder to find manifolds for gsr heads from time to time, not too much of an issue anymore
there are the facts, make your own decision.
Old Sep 27, 2006 | 03:37 PM
Default Re: b16a or b18c1 head for build which is better?? (xDEFTONESx)
thanks man..
Old Sep 27, 2006 | 05:57 PM
h224thgensedan's Avatar
http://www.importreview.com/re....html
found that a while back when a friend was thinking about lsvtec
Old Sep 27, 2006 | 06:13 PM
b16civster's Avatar
Default Re: (h224thgensedan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h224thgensedan &raquo;</TD></TR><TR><TD CLASS="quote">http://www.importreview.com/re....html
found that a while back when a friend was thinking about lsvtec</TD></TR></TABLE>
that doesn't sound right ....... a ported b16 head made less power then a stock gsr??????
sounds like he might hve had a bad port job
Old Sep 27, 2006 | 06:30 PM
ne3ek's Avatar
Default Re: (b16civster)
oh dear.. we're in for a lot of debate now!!
GSR intake ports are bit different than b16 not only the bolt pattern
I prefer b16 for the wide array of intake manifold avail and most intake mani's are designed for a b16 and later fitted for a gsr. besides b16 heads are pretty easy to get a hold of since they've been around longer.
Old Sep 27, 2006 | 06:51 PM
Default Re: (ne3ek)
well i have both heads.. im just trying to figure out which one to build on my gsr block..
Old Sep 27, 2006 | 07:23 PM
by no means am i trying to start a debate. I just remeber seeing that and decided i would show it to him.
Old Sep 27, 2006 | 07:48 PM
yeah thanks man.
Old Sep 27, 2006 | 08:08 PM
b16civster's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h224thgensedan &raquo;</TD></TR><TR><TD CLASS="quote">by no means am i trying to start a debate. I just remeber seeing that and decided i would show it to him.</TD></TR></TABLE>
no no i wasent saying it abt u it is abt the person that wrote it
Old Sep 28, 2006 | 03:58 AM
black_EM1's Avatar
Community Builder
Community Influencer
Never seen one of thewse threads before.
Old Sep 28, 2006 | 08:17 PM
Default Re: (black_EM1)
yea so keep it going!
Old Oct 10, 2006 | 12:05 PM
Default Re: (E1337ulga)
bump
Old Oct 10, 2006 | 12:28 PM
K20CIVIC007's Avatar
ur RIGHT... i hurrd that also...that...they have...more flow..to them...and there cheaper.so i say sell the..B18c1...heads..and buy sum..b16..and have extra money 4 GAS!!...ha ha.. good luck
Old Oct 10, 2006 | 12:41 PM
wolve's Avatar
Default Re: b16a or b18c1 head for build which is better?? (K20CIVIC007)
gsr has more compression of the bat because of the pentroof design.
as said some find the valve positioning better, especially for extreme porting
b16 heads are more common/cheaper, so if it breaks you'll wont have to change parts.
but i would take the gsr head in combination with the b16 piston and end up with a nice comp. for future mild building (cams,springs,retainers,boltons and a nice 200whp )
Old Oct 10, 2006 | 01:35 PM
Default Re: b16a or b18c1 head for build which is better?? (wolve)
yeah thats what i am probably going to end up doing.. thanks man
spoon95eg
Feb 26, 2006 01:16 PM
hb4u2nv
Jun 13, 2004 03:37 PM
CRXEE8
Dec 8, 2003 11:00 AM
CrazyKoreanCrx
Jan 29, 2003 12:52 PM
MugenSi00
Mar 14, 2002 07:36 AM
