bad throwout bearing.. whats outcome..??
Old Sep 26, 2006 | 03:38 PM
JDM_SOHC's Avatar
Default bad throwout bearing.. whats outcome..??
my throwout bearing is making tons of noise, an since i put on my 6 puck my 3rd gear has a slight grind, but still engages... someone told me that usually happens on all 6 puck clutch's "a gear might grind a lil an its usually 3rd"... anyways, im not gonna be able to fix this for a couple weeks..?? how long will a throwout bearing usually last for when its going bad, an what happens when it finally does take a ****... thanks..
Old Sep 26, 2006 | 04:21 PM
CardDealer's Avatar
Banned
Default Re: bad throwout bearing.. whats outcome..?? (JDM_SOHC)
Modified by CardDealer at 9:04 AM 11/16/2006
Old Sep 26, 2006 | 05:01 PM
JDM_SOHC's Avatar
Default Re: bad throwout bearing.. whats outcome..?? (schlit)
damn... so it'd prolly be worth to do fix this thing ASAP huh.. i wasnt sure how big of a USE the throwout bearing was, thanks for info...
Old Sep 26, 2006 | 05:46 PM
coupe99vtec's Avatar
thats the part that physically pushes on your clutch when you step on the clutch. Shoulda been inspected at the same time you changed the clutch, if a shop did it, tell them to open it back up and isntall one, if it was you... be smart man...
Old Sep 26, 2006 | 07:16 PM
bhed-w's Avatar
Default Re: (coupe99vtec)
don't forget that a to bearing can make noise for years before it fails..right?
Old Sep 26, 2006 | 08:09 PM
Syndacate's Avatar
Default Re: (bhed-w)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bhed-w &raquo;</TD></TR><TR><TD CLASS="quote">don't forget that a to bearing can make noise for years before it fails..right?</TD></TR></TABLE>
Yeah but it's not worth it to risk it. Though it usually doesn't matter either way. Buy a whole clutch kit, clutch, flywheel, and throwout bearing. But if you just put the new clutch in, that'd be useless, so new throut bearing ASAP = .
Old Sep 26, 2006 | 08:32 PM
EX-T's Avatar
Default Re: (Syndacate)
If it's a D series tranny, I have a million dollars that say it's the input shaft bearing. And for the 3rd gear grind, that doesn't have anything to do with the clutch!
Old Sep 26, 2006 | 08:38 PM
JDM_SOHC's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by coupe99vtec &raquo;</TD></TR><TR><TD CLASS="quote">thats the part that physically pushes on your clutch when you step on the clutch. Shoulda been inspected at the same time you changed the clutch, if a shop did it, tell them to open it back up and isntall one, if it was you... be smart man...</TD></TR></TABLE>
its brand new clutch an flywheel kit... prolly about 2 weeks old, i drive through a lot of flooded roads an **** when it rains down here so im thinkin a lot of water/dirt got up in my tranny an ****, is that possible..??
Old Sep 26, 2006 | 09:22 PM
Nameless Warrior's Avatar
Default Re: (JDM_SOHC)
So, how can you tell if your Throw out bearing is shitting? I have a B16 tranny.
Old Sep 26, 2006 | 09:49 PM
SoHc94's Avatar
i had a mechanic tell me my throwout bearing was going bad... he was like that sound is the bearing. turns out it aws my ******* exhaust head shield rattling. took it off and now im all good... just make sure theres no loose parts making that noise.
Old Sep 27, 2006 | 03:32 AM
black_EM1's Avatar
Community Builder
Community Influencer
Default Re: (Nameless Warrior)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nameless Warrior &raquo;</TD></TR><TR><TD CLASS="quote">So, how can you tell if your Throw out bearing is shitting? I have a B16 tranny.</TD></TR></TABLE>
Whining noise as you're accelerating. I have a bad one in my Si. And it's been that way for about 6 months.
Old Sep 27, 2006 | 05:12 AM
ChadB's Avatar
All it's going todo is make a noise. I would not over look it. If you are going to auto-cross or drag your car on the weekends. I would get replaced now!
Old Sep 27, 2006 | 06:46 AM
postman's Avatar
Default Re: (ChadB)
https://honda-tech.com/zerothread?id=1657228
Old Sep 28, 2006 | 07:56 PM
good example.
No dirt cannot get into the tranny cuz you drive through puddles, if your tranny was taht f*cked, you would know, since ur would be driving.
Also as stated, check your inout shaft pilot bearing. also the input shaft, that will make it wobble in the tranny, making gear selection more difficult, and could lead to catstrophic tranny failure, like gear teeth (not syncros) getting fcked, saw it on an F550 tranny. Ouchies. a $10 bearing can cost ya $400+ for a used tranny if u dont get that **** done bro.
Smb42069
Jun 14, 2013 06:17 AM
peterphn
Transmission & Drivetrain
Oct 26, 2012 11:56 AM
viet4sh0
Aug 14, 2012 02:37 PM
pa2play
Jul 28, 2005 09:42 AM
Slow_Boy
Jan 14, 2004 04:44 PM
