turn signals dont work, everythign else does. s2000 cluster
ok this is a weird one i think... i wired up an s2000 cluster into my 93 hatch.. last week everything worked as it should, including the turn signals. today i plugged the cluster back in and noticed the turn signals dont work. everythign else is fine though.. heres a rundown of what i checked:
-no turn signals at all
-hazard button plugged in and hazards work
-all lights work, including corners etc and with the hazards
-changed the turn signal switch to a known good one and tested the old one and it was good
-changed the flasher relay to a known good one
-made sure wires were still wired together and plug was in all the way. i even disconnected one wire and played around with it, and made sure it shut off one of the arrows on the cluster with the hazards on, which it did
is there a turn signal fuse somewhere? i didnt see anything listed on the fuse box thing.. helppppppp
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Type-Ek »</TD></TR><TR><TD CLASS="quote">bro, fast blinkers are ricey</TD></TR></TABLE>
bro, wtf are u talkin about? nobody said anything about fast blinkers
2LGSR
Oct 7, 2010 08:35 PM
JDM96SpecCTR
Sep 27, 2006 04:17 AM
