Low RPM knock (almost stall RPM)
Anyone know what causes this?
It happens once in awhile If I am engaging the clutch while driving, and if Im not paying attention and let the RPM's fall too low, the engine will knock and sputter a bit untill I give it more gas to get going..... sounds pretty bad, so I try and avoid it as much as possible.
I also heard it again today while seafoaming, I had the PCV valve off and the RPM's were fluctuating and at some points I had allot of seafoam going in and the RPM's dropped very low, so low that it did that knock again, weird...
i wouldn't go as far as saying he needs a new motor.I think when a car is about to stall it usually knocks, right? Is you're timing off? or to keep the rpms from falling play with the idle screw adjuster.
Yeah I have heard other cars knock when they idle too low, and about to stall. I did a search on google and found a few tidbits of info saying it is related to pre-ignition I think that causes the knock at very low rpm (correct me if im wrong).
It runs fine any other time, I guess i just let it idle down to low under load (letting it sip the seafoam, did not let it hydrolock)
Timing isn't off I don't believe. I definately need to adjust my idle though, it goes down too low when I let off the throttle then chokes and goes back up to around 650-700 rpm again.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Cottonwoodz »</TD></TR><TR><TD CLASS="quote">A motor pings, not knocks when about to stall.... Two really different sounds... But he did say KNOCK
yeah....if a motor knocks at any rpm you've got problems
</TD></TR></TABLE>yeah....if a motor knocks at any rpm you've got problems
it was probably pinging then. I havn't heard the difference between a loud knocking motor and a pinging one, but i was just trying to describe the sound, it was subtle, nothing that really drew attention from neighbours or anything :D
does it sound like you have a bunch of rocks in your engine?
id check your O2 sensor and wiring. because if the ecu is getting a bad a/fr from the O2 sensor its throwing off your timing to compensate... check your CEL
Modified by honda head at 2:58 PM 10/3/2006
yes it sounds very familiar to rocks in the engine, but it wasn't RPM dependant, if i revved it up there was no sound, just happend that 2 times when it was about to stall.
Will tightening up my throttle cable stop the enging from dipping to low when coming off throttle?
I have this side issue that when Im driving, sometimes when I let off the gas and in neutral (at a stop light etc, the RPM will drop down to about 200rpm then after a sec or so jump back up to aroun 75p rom again.
Or is this something very different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by loudsubz »</TD></TR><TR><TD CLASS="quote">Will tightening up my throttle cable stop the enging from dipping to low when coming off throttle?.</TD></TR></TABLE>
try the throttle body idle screw
Dapatra
Honda Civic (2006 - 2015)
May 23, 2019 05:45 PM
Civic082382
Oct 23, 2010 05:41 PM
[626]95-GSR
Aug 21, 2003 02:34 AM
