Rod/Stroke ration + Comp
Old Sep 26, 2006 | 12:58 PM
mikkey1's Avatar
Default Rod/Stroke ratio + Comp
hey ppl
just need a little help here, ive searched but cant find any answers, or an r/s ratop calculator,
basically i need to know if this is reliable or not.. or what are my alternatives,
b16a Head
ITR Block
ITR 81.25 pistons
ITR Con Rods
89MM crower Crank
Could someone tell me what the R/s ratio will be ? also weather this will be safe and any alternatives (baring in mind i cant use after market pistons because i aint got them or after market rods) however, b16 rods are avalible, aswell aswell ctr pistons and b16 pistons
thanks
Modified by mikkey1 at 2:47 PM 9/26/2006
Modified by mikkey1 at 2:48 PM 9/26/2006
Old Sep 26, 2006 | 01:26 PM
GSRCRXsi's Avatar
Default Re: Rod/Stroke ration + Comp (mikkey1)
you cant use the ITR rods with the 89 crank. you'll have to get LS sized rods.
Old Sep 26, 2006 | 01:46 PM
mikkey1's Avatar
what would be the btter option, consdering ill be using todaCs, so will need quite high comp.. ?
Old Sep 26, 2006 | 02:24 PM
GSRCRXsi's Avatar
Default Re: (mikkey1)
use either LS rods with ARP bolts or get some aftermarket LS size rods. you can keep everything else the same
Old Sep 27, 2006 | 04:00 AM
mikkey1's Avatar
had a word with someone today, if i use a thicker Headgasket , am i correct to believe that this will clear and be ok?
anyone confirm that please?
Old Sep 27, 2006 | 05:10 AM
D-Rob's Avatar
I talked to you about this matter in a PM, didn't I?
Just get LS rods with ARP bolts. Why take the chance with a thicker headgasket?
Just use the right parts to begin with.
Old Oct 4, 2006 | 10:32 AM
mikkey1's Avatar
we dont have GSR rods here in the UK, so im having to use a thicker headgasket!
i mean if the HG is the correct thickness there shouldnt be a problem right ~?
Old Oct 4, 2006 | 10:59 AM
EH3SiGRL's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mikkey1 &raquo;</TD></TR><TR><TD CLASS="quote">we dont have GSR rods here in the UK, so im having to use a thicker headgasket!
i mean if the HG is the correct thickness there shouldnt be a problem right ~?</TD></TR></TABLE>
they all said LS rods, not GSR rods
Old Oct 4, 2006 | 11:04 AM
2fast4u831's Avatar
I'm really 2slow
Default Re: (EH3SiGRL)
check out our sponsors here on honda-tech for some LS rods
Civic138
12
Feb 9, 2007 03:03 PM
CRX MASE
Mar 31, 2006 09:06 PM
Mr. Em1
Feb 12, 2006 06:58 AM
JDMdaN.A
Apr 5, 2003 04:26 AM
tysir
Aug 16, 2001 11:50 AM
