del sol seats-eg
Old May 1, 2002 | 09:03 AM
NiiS's Avatar
Default del sol seats-eg
what is the most common way to install the del-sol seats?
do you use civic rails/hardware or del-sol stuff?
i used civic stuff-is this the common way?
the way it is now, they look stock (which is good), but i'm wondering if i should have done it different so the seats would sit lower in the car.
[Modified by sinnister, 6:15 PM 5/1/2002]
Old May 1, 2002 | 09:52 AM
hybridreams's Avatar
Default Re: del sol seats-eg (sinnister)
It's going to sit low no matter which rails you use. I used the Del Sol rails.
Old May 1, 2002 | 10:00 AM
SyndicateEH's Avatar
Yes, in a civic you use the civic rails. My delsol seats sit hella lower than my factory seats. At first I didn't like it, now I wouldn't have it any other way.
Sounds like you did it right, but the seats should be lower.
Old May 1, 2002 | 10:06 AM
ZXVIIR's Avatar
Default Re: del sol seats-eg (SyndicateEG)
done it as well,
i swapped the civic rails on the sol seats,
and all said was done. very easy.
X2BOARD
Mar 19, 2012 10:04 AM
mtownek9
Oct 14, 2007 09:48 AM
91teg
24
Mar 3, 2004 02:17 PM
Red AEM Civic
25
May 16, 2003 11:03 AM
dgdarien
35
Apr 19, 2003 01:08 PM
