lower control arms
Old Sep 26, 2006 | 07:37 AM
superbangkok's Avatar
Default lower control arms
take a look at these:
http://www.jhpusa.com/catalog/...=1038
also i've found others with a solid piece. my question is, how do the struts bolt up to a solid piece?
with the stock lower control arms on my 95 civic, the metal spreads at that point and the strut drops down into the middle, then the bolt travels through.
would the strut with these aftermarket ones, just bolt up on the inside of that solid piece, does not seem right, comments ?
Old Sep 26, 2006 | 07:42 AM
Mr Hammond's Avatar
a/k/a Jomo
Default Re: lower control arms (superbangkok)
Those arms have the exact same three bushing mounts and rear sway bar mount as a stock rear lower control arm. I am failing to see your question. They are bolt-in, just lighter.
Old Sep 26, 2006 | 07:46 AM
nonsense's Avatar
sounds like you have ITR rear LCAs on your Civic?
do yours look like the one on the left or the one on the right?
Old Sep 26, 2006 | 07:49 AM
Default Re: lower control arms (nonsense)
mine look like the ones on the left side in your picture, am i screwed ?
Old Sep 26, 2006 | 08:01 AM
BLUE EH3's Avatar
Help we my pennies
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by superbangkok &raquo;</TD></TR><TR><TD CLASS="quote">mine look like the ones on the left side in your picture, am i screwed ?</TD></TR></TABLE> ur fucked.. the left is itr lca.. u need the right side for 92-00 civic
Old Sep 26, 2006 | 08:14 AM
nonsense's Avatar
no, not really. Just don't get blingy rear LCAs. The only problem with having the ITR rear LCAs is that you will have less choices when you have to get new rear shocks. If you're dead set on getting blingy rear LCAs and you want to keep the ITR rear shocks Function 7 makes them for the ITR.
Old Sep 26, 2006 | 08:46 AM
Sleepy_Red_hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nonsense &raquo;</TD></TR><TR><TD CLASS="quote">
yup....except, ALL LCAs off JDM EGs and DCs are like that, not just JDM itrs
relentlesstech
30
Mar 4, 2014 03:09 PM
gsr_b20b
Jun 18, 2011 08:00 PM
D15B Civic
Suspension & Brakes
11
Apr 30, 2010 10:47 AM
BG-Teg
Jun 3, 2007 06:54 PM
water
Mar 6, 2004 08:40 AM
