HELP !!! I´ve melt 2 spark plugs using CIVIC R pistons, HELP !!!
My ITR today just stop after the first hard drive after break in period.
Hard drive only for 3 minutes, in 5º gear.
I called a mechanic and after trying to put the engine ON, he removed the plugs and the 1st, 2nd cilinder was completly melted, i couldn´t believe it.
We could see trought the plug that the pistons are destroyed, i´m running 16´s timing and stock injection, no fuel add on the V-AFC.
Help, Help !!!
Help, Help !!!
Help, Help !!!
Help, Help !!!
I couldn´t hear the detonation cause of the exaust, too much noise.
The ITR was pulling ok, when it happened.
I was about 150 mph, ( for 1 minute only ) usually it goes over 162 at red line, that was with the stock pistons. I was about 60% of throtlle.
I can´t believe this is happening to me, i spent a lot of money on this and now i´ll have to open the engine again and check how the cilinders are and the pistons.
What do you think, the metal pieces of the plugs are gone trought the exaust valves ?
My timing adjustment is almost in the max, only 2 mm before the max, and it is at 16 timing.
I told my Honda mechanic to low the timing to 13 or 14 but he didn´t listen to me.
The B16C6 head is diferente from the B16C5 engine.
I´m so %$#&# with this.
SGT any thoughts ????
[Modified by pinota, 6:29 PM 5/1/2002]
B18C6 head is same as B18C5 head.
So you took it to 150+mph without tuning?
I assume you have no extra fuel(and you CANT add fuel with a vafc)
what were you thinking? You have noone to blame for this situation but
yourself. I think you will find some marks on the pistons and possibly
the chambers on the head. Hope your valves didnt sit down on those pieces
or you will have a lot more to worry about.
[Modified by Rguy, 10:38 AM 5/1/2002]
SGT what do you think that caused this ?
Detonation, because the timing advance or fuel lean ?
I´m using 98 octane fuel.
Thanks.
Help, Help !!!
Help, Help !!!
My honda mechanic told me 16 is the stock timing advance, + or - 2 degrees.
So he thinks this is the best timing advance.
I told him to put the timing at about 13 or 14 but he didn´t care.
Also he told me not to adjust the fuel curve in the V-AFC during breake in.
Stupid !!!!!
Hi just rev for 1 or 2 minutes in 5º gear, i never thought this could happen.
Stupid !!!!!
1-2 MINUTES???? Geez man.
You need more pressure or larger injectors to add fuel. VAFC isnt able to.
You probably ran it real lean or just detonated. I would put my money on
detonation. Have fun rebuilding the motor... again.
btw, you dont have much room to be calling your mechanic stupid.
He isnt the one who did high speed runs in your car.
My mechanic told me that the timing should be 16º.
I explained him that someone here from the forum told me to delay it to 13.5º or 14º.
But he didn´t agree on that.
Now my motor is $#&$%$, ok...
whatever doesnt cause detonation and you NEED MORE FUEL!!!!
you NEED to STOP RACING and PUSHING THE MOTOR until you have it PEROPERLY TUNED!!!
SGT, do you think i can raise the fuel with proper settings on the V-AFC ?
Does the V-AFC really raise the fuel up to 50% ?
Sorry, about these questions, but i have a V-AFC, but i wasn´t using it cause of the break in period, before the CTR pistons i was using +12 at 8k, max.
Thanks,
Pinota
Thanks,
Pinota
