what's a good camber kit?
King or Skunk2 - very easy to adjust. You can do it at the track with a jack and a 5mm allen key.
Lemme ask this question.
King Motorsports, Front: $400, Rear $375.
versus
Skunk 2 Front: $190, Specialty Products: $100.
Both products look to be the same style... is there that big of a quality difference?
Any problems with the Skunks Slipping?
versus
I've got two of the King kits and a guy I share the garage with has the Skunk.
The weld gusset on the King kit appears to be much more "beefy" than the Skunk. The ball joint looks to be of higher quality than the Skunk. The Ball joint plate is definately more "beefy" on the King unit.
Often times you get what you pay for. I'm not saying that is the case here, but in general that is true.
Peep the websites... although I'm sure someone will post the pictures:
http://www.skunk2.com/html/suspension.htm
http://www.kingmotorsports.com/products/king/
and for the rears, I'm looking at:
http://www.specprod.com/PROD_DIR/PROD_PASSCAR.html
King
Skunk
Notice the reinforcement plate on the bottom side. The King unit goes further back. I believe the King is a modified stock piece and the Skunk is their own stamping. One last thing is that the King kit comes with the bushings and connection points. The skunk requires you to use your old one.
Skunk
MidwestSi
Mar 9, 2005 04:15 PM
Asild
32
Feb 10, 2002 06:40 AM
